Went to start up my car again today and I get the same results, starts and then stalls 2 seconds later. Except now if I try to give it gas, the check engine light flashes constantly until it dies. I checked for codes and there are none. Does this mean I have a bad ECM or something?
Are you trying to start the car with the top two ALDL connector ports jumped? Field service mode will make the ses light flash quickly. The only other time I've seen a check engine light flash that fast when the car was running, was when we drove my brothers WS6 to the shop with open headers, the light was blinking because no oxygen sensors were detected. I don't know if that is applicable to our c4s or not. When you pull the codes on your car, are you getting the code 12 (ecm ok) code?
do you have a owner's manual? read where it says if it flashes, you have to get it fixed now!
ok, you have to pull codes to find out what's wrong.
A. use a paper clip, short out the two lower R/H pins in the plastic connector on the right side of your left dashboard right where your right knee is.
B. turn on the key, don't try to start the engine, and the check engine light will start flashing and the cooling fan will start running on it's own.
1. the check engine light will flash once then twice 2 times.
2. then start counting the flashes. like 3 flashes, a pause, then 4 flashes. that equals code 34
3. get all the codes written down, then it flashes once then twice 2 times. that means you are at the end of the codes. it will start all over again till you take out the jumper and turn off the key.
4. Buy a manual, even a haynes manual from autozone will have the list of codes.
welcome to the fuel injection part of your life.
No codes, hmm it could be the computer. From people on here that have had trouble with them, it can be tough to tell without trying one. If you run a search there are a few topics on bad computers. I looked into that awhile ago since mine had some odd symtoms. Have you thought of getting one from a local place and trying it? If it doesn't help then you can return it.
A. use a paper clip, short out the two lower R/H pins in the plastic connector on the right side of your left dashboard right where your right knee is. The two UPPER R/H pins.
1. the check engine light will flash once then twice 2 times. Three times. All codes will flash 3 times, including code 12.
3. get all the codes written down, then it flashes once then twice 2 times. that means you are at the end of the codes. it will start all over again till you take out the jumper and turn off the key. As I said above, three times.
4. Buy a manual, even a haynes manual from autozone will have the list of codes. A Haynes manual will probably identify what circuits the codes came in on, but you will need theFSMto properly trouble shoot the cause of the codes. A code for the EGR valve doesn't mean the EGR valve is bad, just that a malfunction occurred on the EGR circuit.
If the Check engine light comes on while the engine is running, a code is supposed to be set. If you truly have no codes, check your FSM trouble shooting charts for that symptom.
I'm betting it's bad gas. You can always get a little sample by going to the fuel rail and getting a sample from the fuel pressure schrader valve. bad gas may be a long shot but hey, it turned out to be one of my problems. Well my car's problem not mine.
Nope, I checked it today. No leaks of any kind and its getting fuel just fine. Just got fuel roughly 2 weeks ago and ran fine for the first half tank, still sitting at half tank.
Anyway, my bud looked at it and thinks it could be a bad alternator. Seeing as how the battery is new along with plugs, wires, etc. I could see that. I dont know when the alternator was last replaced. I know that if I keep feathering the gas eventually it will stay running just fine once warmed up. Is it worth having it checked?
