Replacing Intake Gasket... what else??
Oh yeah... it has roughly 90,000 miles.
In my case, I pulled everything apart and did a major cleaning and replaced anything and everything that I could while I was in there.. water pump, belt, hoses, clamps, sensors, EGR valve, fuel injectors..everything. Unfortunately, I should have followed my gut instinct and done the head gaskets while I was down that deep but decided not to.. Well, now I'm replacing them just a short time after getting everything back together
Just keep very careful track of where every bolt came from and label your wiring harness as you unplug stuff.. I used baggies and a permanent marker to keep track of the bolts.. a seperate baggie for each item I was taking apart..
Another tip would be to get the car up nice and high on jack stands and remove the front wheels.. that way you can stand right in next to the motor without bending over all day.. it's much nicer on the back.
Good luck~
http://home.comcast.net/~redlineguy/89vette.html
(has a few pics and write up on what I replaced)
