A few weeks ago I purchased some Hooker 2151's from Summit to be used on my rebuilt engine. I went down to the garage today to see how the build was going, and they told me the headers would not work with my engine. They said Hooker Headers would not work with the L98 engine because it has angle plug heads. Now i'm pretty mad because I called Summit and told them what engine I had, and they told me about these. I called Summit today and told them what happened, and this time the guy tells me they won't work. Now I've seen threads about people on here running these headers. Can anyone explain to me what the heck is going on? My mechanic said the only way the Hookers would work, is if he drilled holes for the spark plugs. We ordered some Hedman headers instead. Sorry about the length. I'm going to the cabin later this evening so I apologize that I won't answer back over the weekend. Long weekends are great!
Something is either seriously wrong or not being divulged. The 2151s work with straight plug heads and heads with the L98 angle. They don't work with AFR heads with the proprietary AFR angle plugs. You lead us to assume you have L98 heads. That makes me wonder what your mechanic is smoking. Have him mock up a header to one of your heads and show you how they don't work. They ARE the correct 2151s, aren't they?
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That's pretty odd since the Hookers are made for the L98 C4. They're also commonly used on the LT1/4 cars with few major issues reported in either case. Now I'm even more suspect of your installer after the issues that he had with the Doug Thorley headers that I sold to you. They were reportedly nearly dragging the ground. But after I got them back, they have only one inch less ground clearance than my SWs or my DRM headers have. This would still be over 5" of clearance and not the 2" of clearance that he claimed. Something is very wrong here.
On the Summit site it says they will fit 84-91 Corvettes, but just not with AFR angle plug heads. I called around to a few part places around here and they also said the hookers would not fit with my engine. My heads do have GM casting numbers, but I don't have a clue if they are originals. They are angled. The problem is that the header will be covering some of the spark plug holes.
They are the hooker 2151's, atleast according to my bill.
The part number is HOK-2151-1HKR.
Thanks guys!
Thanks guys!
I know that L98s from '88 on (113s) are angle plug. I'm unclear on the earlier versions.
I have a 90 so it should be the same. Is there anyway to tell if they are 113's? Even though they are angle plugs the headers should still work right? Is there anyway to tell which headers I have? Are there markings of some sort? The only thing I can think of is that I either have different heads, or the wrong headers.
Look at the casting number, it will end with 113. If they're like LT1 heads, the number's under the valve cover.
What drilling to fit plugs ????? that's insane, you have the right number and many here have those on l98's and lt's, mine are the 2149, same header, same year, difference is these are w/air, egr, I can't imagine where the problem could be.
Your 90 should have 113's unless someone did a swap.
Did someone put a diferent motor in the car, or relocated it in some fashion? Did the guy actually try and fit them on the car or can he just "tell from looking" at it ?
I don't remember if the number is on the flange, but if you seen they don't fit for yourself call and get another set sent out. I guess it's possible someone packaged them wrong.
Well i'm extremely confused over the situation. He told me that he tried to fit them and they won't work. I knew that these should of fit when I got them. I'm going to talk to him on Tuesday about this more. I will even show him this thread. Like I said maybe the headers aren't the right ones, or I have different heads. Thanks everyone.
I have a pic in my pics you can see but they are the 2149's, if it helps. I do my own work so I can tell you they fit fairly easliy, the drivers side in fact can be put in from the top of the car once everything is out of the way.
Forum member -=jeff=- comes to mind with 2151's and 113 heads if that helps. The guy trying "to fix" them I hope you will still be able to send them back and get another set. If you can see the spark plug being at an angle they should have been alright. The only place mine were tight at was near the heat shields located on the lower floorboards.
Thanks for the pic. They are hard to see but I can make them out. Do the headers have any markings that tell which model they are?
I have a '91 w 113 heads and 2151 headers-no problems here.
Is there anyway you can get pictures of the fitment issues? I'd be curious to see what the problem is.
If you click on My Corvette Photos you can see a couple of pictures.
Thanks your pictures are alot easier to see. I'm going down there on Tuesday and am going to make him show me.
If you have stock heads they should fit. Many L98 guys here are running them, including myself. Either they sent you the wrong ones, or your heads aren't stock.
86PACER, those pictures are exactly what I wanted. I am definitely showing them those pics if they still say they won't fit. Thanks alot!
the other alternative, and since no one else really mentioned it.....perhaps the previous owner did something to it or something was done/or happened to this car that we can't see.
Hopefully it is just the guy working on it...I'm going out to do some work on mine I will look to see if there is a visable# if so I will take some shots for you.
The ONLY problem I've ever seen with Hookers (2151's or 2149's) with regard to any sort of fitment problem on a C4 is the engine mount bolts hitting the tubes, causing lineup problems. This is a simple fix.... support the engine, remove the bolt and put it back in place from the opposite way (placing the bolt head at the back of the mount instead of the front). You have to be a complete moron with 7 thumbs on your hands for these not to fit... The "drilling for spark plugs" issue most likely relates to the plug wire brackets.... again, easy fix. Grind off the offending metal (on the BRACKET, not the HEADER FLANGE), and secure as necessary.
