alternater replacement
Old May 19, 2007 | 11:15 AM
Iroc57's Avatar
Iroc57
Default alternater replacement
I am posting but it is really my son's car. He won't do a sig pic until he gets his car painted.
My question....
Without a service manual yet I'm sure that the experience here can direct me to the serpentine belt tension adjustment procedures.
1991 coupe
Thanks in advance
Old May 19, 2007 | 11:23 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
My question....
1991 coupe
Thanks in advance
unless it's different than my 85, there is no adjustment. You take the tension off to take off the belt and the oposite when reinstalling
Old May 19, 2007 | 11:24 AM
ineVETTEable's Avatar
ineVETTEable
Should have automatic belt tensioner/pully. push away from belt to unload tension.
Old May 19, 2007 | 11:28 AM
jfb's Avatar
jfb
Your son's 91 Corvette has a spring loaded belt tensioner on the right side of the engine and no adjustment is necessary. There is a 1/2 " square hole in the tensioner arm that you put a 1/2 " breaker bar in to unload the belt tension to remove the belt, and you do the same to install the new belt .
Old May 19, 2007 | 02:47 PM
Iroc57's Avatar
Iroc57
Worked like a charm!
These cars are pretty easy to work on.
Thanks to all
To alternater replacement
