12.89 1/4 times
Old May 20, 2007 | 03:11 AM
johnwayne's Avatar
johnwayne
Default 12.89 1/4 times video
high five ever body just ran a 12.89 with .989 start with a 109 mph. not to bad for street tires. roasted them all first gear and small part of second!
Old May 20, 2007 | 04:31 AM
Driftmonster's Avatar
Driftmonster
Post the time slip.
Old May 20, 2007 | 08:08 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old May 20, 2007 | 08:11 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
whats ur mods?
Old May 20, 2007 | 08:38 AM
franks96ce's Avatar
franks96ce
those are good times,i wanted to go last night but they kept me at work until 11:00 so keep in touch so we could possibly meet up next time and hit the track.
Old May 20, 2007 | 08:40 AM
Razor89's Avatar
Razor89
Old May 20, 2007 | 09:46 AM
Aardwolf's Avatar
Aardwolf
Originally Posted by BADDUCK
whats ur mods?
Nothing in profile about them either. Good run though!!!
Old May 20, 2007 | 09:59 AM
cv67's Avatar
cv67
St. Jude Donor '05
whats ur mods?
Old May 20, 2007 | 11:36 AM
jslt1's Avatar
jslt1
Old May 20, 2007 | 12:11 PM
cv67's Avatar
cv67
St. Jude Donor '05
Originally Posted by jslt1
Old May 20, 2007 | 02:23 PM
johnwayne's Avatar
johnwayne
O.k. heres the mods superram upper inake and a edelbrock base 58mm throttle body, stock injector, adjustable fuel pressure, stock heads that i had punched out to a 2.02 inake and 1.60 exhaust, lower end is stock block that i punch out to a 383 srp piston and eagle rods and crank. stock six speed with a slipping duel mass flywheel and rams top high preformance clutch. headman header and borla exhaust no cats.
Had the car dyno tuned at 323rwhp and 419rwtq.
heres how the time slip looks givin i rolled out the light not dumped the clutch.
.9295 .......reaction
2.1466......60ft
5.5360......330ft
8.3820......1/8et
86.94.......1/8mph
10.8067....1000et
12.8739....1/4et
109.65......1/4mph
Old May 20, 2007 | 02:26 PM
johnwayne's Avatar
johnwayne
just send me a pm when you want to go.
Old May 20, 2007 | 11:22 PM
johnwayne's Avatar
johnwayne
Old May 21, 2007 | 02:04 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Very nice!
Old May 21, 2007 | 08:26 AM
comp's Avatar
comp
Old May 21, 2007 | 09:40 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
John looked like a great run especially on street tires and I think the run in the hill country was good for your Stroker
Old May 21, 2007 | 11:37 AM
SCCA VETTE's Avatar
SCCA VETTE
2.1 60 foot That car has 11's in it!
To 12.89 1/4 times
Old May 21, 2007 | 01:11 PM
NitrousSam's Avatar
NitrousSam
I agree because you have a hi torque engine and you are blasting the tires in all of first gear and part of second...the 60 foot is a sure sign that you are spinning AND you are also losing track position in the 1st 1/8 mile because of it. Your can has a bunch more ET in it if you can get it to stick for the first 100 feet.
Old May 21, 2007 | 02:47 PM
johnwayne's Avatar
johnwayne
I hear the car ping coming from the motor on when full throttle. I think i'm starving for fuel on the upper end of the power band. what size injector should i run? I have the msd box. I really need a set of slicks or DRs.
Old May 21, 2007 | 02:51 PM
comp's Avatar
comp
have you upped the fuel pressure any
