From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Stock valve covers I assume? The Pro Mags should be no problem. You may have to shorten your drip tabs but I'm not even sure about that. It seems that some have said that's not even needed for them with the composite covers. My stock covers, which I was still using then, had already been modified for a previous set of aluminum roller rockers when I switched to the Pro Mags so I can't say for sure. You're doing the right thing just going ahead and getting the 7/16" ones to start with, I wish I had. At the time though a cam was my biggest mod. I had no idea I'd ever get so carried away. You'd think I'd know myself better by now....
Originally Posted by BADDUCK
Apparently 7/16" studs and narrow SA is mutually exclusive.
Yeah I'm pretty sure that 7/16" rules out the SA part but he didn't mention that. The Pro Mag is as narrow as he's likely to find, as far as I know. I had to go and look at my factory covers. I didn't remember the reinforcing ribs and assume that this is where his concern lies. I don't know but is the fulcrum shaft wider on a 7/16" Pro Mag than on the 3/8" version? That's the only possible source of interference that I can imagine he'd encounter other than the aforementioned drip tabs.
From: One day you're a Comet...the next day you're dust... Arkansas
I don't know about Pro Mags but I looked at Scorpion, and Crane, and neither makes what he is looking for. I thought the "narrow" was to clear the centerbolts.
Maybe that's it. But if so, I can think of an easy work-around for that.
Originally Posted by LD85
Yes I am, this is the widest point
No difference on the 3/8" version, also 1.625" or 1 5/8" for those who don't wish to do the math. . But now I've also seen that it's a moot point. The cover bolt passes through well below the fulcrum and so should not be an issue. I realize though that the rest of the 7/16" rocker (it's main body) is indeed considerably wider. But for those who are familiar with the design of the factory valve cover hardware for the composite covers, I'm sure you can visualize the simple solution that I have in mind, were they to be an issue at all.
I'm running the CC Promags with 7/16" studs and stock valve covers. I removed the drip tabs (not sure I needed to but in only took a couple of minutes) and NO DRAMA>
Valve train
all buttoned up Notice 58mm TB with factory air intake (response to numerous threads about it won't work)
Mike
Comp Cams Pro Magnum 7/16 stud RR's will work. They aren't classified as a "narrow body", but are the same width as their self-aligning rockers that are made for the LTx engines.
The pic I posted are c.c. p magnums 1.6, 7/16" stud, full rollers, s. allign. Anything alluminum (that is shown as "narrow body") is visually wider. I don't believe you can get any narrower at the stud. If I remember, comp. cams has dimension specs. posted on their site, and did list a 1016-12 as a narrow body which no longer reads as 7/16 stud.
Okay, thanks for all the info. I was under the impression that if the advertisement didn't specifically say "Narrow Body" I'd have a 'not easily solved' interference issue.
So, what I came away with is the CompCams Pro Magnums, which can be gotten with 7/16" studs, will probably clear the covers BUT, if not, the mod to make them clear is pretty simple. Just a little grinding.
I've already installed hardened guide plates and ARP 7/16" studs, so all I have to do now is grab a set of ProMags.
Once my pushrod length checking tool arrives I can them move on to measuring and ordering the correct length hardened rods.
I'm looking at Crane's 10308 valve spring kit; comes with double springs, retainers and locks.
Just curious, what length of studs did you get? Generally a 1.75" or 1.825" is about right for using polylocks on these engines. This is a bit longer than stock.
