Problem with short shift kits (4+3)
Old May 21, 2007 | 11:23 AM
Chatman's Avatar
Chatman
Default Problem with short shift kits (4+3)
I wrote just over a week ago about short-shift conversion parts that I received from madvet. I spoke with their technician a week ago (Monday) and we determined that my parts were manufactured incorrectly. I asked that new ones be sent and that they check them before mailing. I was told, no problem, they would be shipped that day. I decided to leave the car on stands to finish the job the next weekend. The parts didn't come by Friday and I called this morning because I need the car back on the road tomorrow.
I just got off the phone with madvet and the parts were not shipped. They were determined to be wrong and blocked on FRIDAY AFTERNOON. So, it took four days to determine the parts were screwed and no one bothered to tell me. Apparently, I was put on a backorder and the salesperson told that it would probably be 2 or 3 weeks. Sounds like their entire batch is junk. They have a notice of "limited stock" at the on-line catalog.
So, a warning on the parts and disappointment with madvet's handling of the situation. Madvet supplies Eckler's, so be sure to check if ordering from Eckler's.
Old May 21, 2007 | 01:10 PM
GRX's Avatar
GRX
Thanks for the warning.
Old May 21, 2007 | 05:33 PM
scorp508's Avatar
scorp508
Ugh, thats annoying. Can you put your stock ones back in for the time being?
Old May 23, 2007 | 11:08 PM
bill83c4's Avatar
bill83c4
ehhh, i need to get a kit. thanks for letting us know
Old May 31, 2007 | 11:28 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default I installed a set this week
I didn't catch this thread before installing. I just installed a set I had purchasd a few months back. I do believe those came from Ecklers but I'm not sure, will have to check all my invoices on-line.
The only problem I had was I had to use the full length of the shift rods when I adjusted the linkage after installation.
What is the issue with the new levers?.
Old Jun 1, 2007 | 12:34 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I wish I would've seen this earlier. I have a used set if you're still interested. PM'd you also.
Imagine how many other customers are in the same shoes as you. Ridiculous.
Old Jun 1, 2007 | 11:36 AM
tdf's Avatar
tdf
St. Jude Donor '11
Default Annoying Part Is The Shifter
Installation of the short levers is easy if the car is up on stands. The time consuming part of this swap is getting to the shifter to insert a 5/8" guage to hold the center possition while you adjust the linkage (the driver seat and console covers have to come out).
The same will be true if I have to reinstall the original set!!!
I started mine and went through the gears while up on stands. It seems to shift good (better adjustment than before). Will have to see when the tranny is under load (wheels down).
Old Jun 1, 2007 | 02:30 PM
CentralCoaster
Not necessary. I did it this way first, but the second time did it by feel without messing with the console at all and had better results.
Old Jun 1, 2007 | 11:17 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default More Than One Way
There is always more than one way to do a job. I did it per the GM shop manual.
Old Jun 2, 2007 | 01:14 PM
rel3rd's Avatar
rel3rd
If he's not interested, I'll probably take them.
Old Aug 7, 2007 | 09:43 PM
Fastboater's Avatar
Fastboater
I installed a set, having trouble getting it out of gear once in reverse. It will go into neutral, but can not get it into 1-4? Any advise on what linkage needs to be adjusted?
Old Aug 8, 2007 | 03:20 PM
kehler's Avatar
kehler
I have a set that I was going to install this coming weekend, shouldn't be affected by the qulity issue as they are at least 5 years old
To Problem with short shift kits (4+3)
