Best brake mods, suggest...
I want to go the opposite side; slower!
I want more efficient braking.
I have read about stainless steel lines, bigger rotors, drilled or slotted rotors, brake air ducts, higher boiling point brake fluid, etc.
But, what about the master cylinder? Is there an after market part that makes braking more efficient, or better?
I have seen after market parts for almost everything but so far nothing related to the master cylinder. After all, this is where pressure will come from.
Lets hear some suggestions.
Seriously though, drilled and slotted rotors make for a great and simple upgrade. Of course you can go all out and get the Wilwood 6 piston brakes. Central Coaster has them on his '85.
Do that, and then see were you are at. It made a big difference in my car.
Kinkajou, to properly answer your question we'll need a little more information. Primarily, why do you think you need better braking, and secondarily, is your car a daily driver or a track car?
There is no reason to replace the master cylinder. There are a bunch of us here with C4's that race competively and successfully with stock parts. So...
If you want initial stopping distance with brakes at ambient temperature on the street (i.e. better braking feel) then change your pads to something more aggressive (like the Hawk HPS suggested above) and put on the stainless steel lines. Your initial bite will be quicker and more controllable.
If you need real, repeatable stopping (on the track), then you'll need to upgrade your calipers to the C5 kit or something aftermarket.
Slotted and drilled rotors will not get you anything.
Problem I had is that sometimes I will push the brake pedal and it will go all the way down, if I push again a couple of times , everything will be ok again.
Brake flud was all changed, new brake pads, rotors are good, I even changed the master cyclinder for a used but in good condition unit.
I really hate to feel that the brakes will not be there when I need them the most.
So I thought that I would try to make the car as reliable as possible.
So far I have heard great ideas, thanks guys.
Please keep those ideas and advice coming!
Could you please explain a little bit on this? I have not heard of this before. How can a caliper be damaged or spread?
How can I inspect the caliper for this kind of damage?
Not sure if thats what you meant by spreading but I was curious if this is true or not?
I remember you had a track event, that is why I suggested caliper damage. You will have to take the pads out to check the piston area. Look for the piston to have kinked sideways in the hole, check the bracket and caliper to be even. They should be like an H, straight and not bent. Do you know what I mean? Here are a few threads talking about damage:
http://forums.corvetteforum.com/show...caliper+spread
http://forums.corvetteforum.com/show...caliper+spread Post #18 here, U shape or H like I mention.
http://forums.corvetteforum.com/show...caliper+spread Post #20 on measuring.
When I work on my brakes, I use a micrometer to measure the rotors wear. The min. thickness of the rotor is stamped the back of mine. I use a piece of metal on the rotor face to avoid the edge of the rotor that is less worn. I also measure the caliper and bracket. When I put new calipers, rotors, and pads on, I measure them new and write this down. Then after an event you can see how much wear there is.
I hope this helps!
