Oil filter warning!
Old May 24, 2007 | 12:13 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Oil filter warning!
Thought I'd share this with you in case you didn't know already.
New oil filters often have metal in them left over from manufacturing. Usually it's steel shavings from when the threads were cut. I've even found the small metal holes that are punched out of the filter core in there. All of this stuff ends up in the filter core (downstream of the filter paper) and when you fire it up gets pumped directly into your bearings.
So when buying oil filters, always tap the filter hard against a table to knock any of this debris loose, and inspect the threads for metal shards that might come loose when installing it. I haven't noticed it as much in the premium filters, but it still happens way too often.
Old May 24, 2007 | 12:25 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Nice to know... I've not seen it in any filters i've gotten, an old mech told me that yrs ago...
Old May 24, 2007 | 12:44 AM
CentralCoaster
That's the standard response from everyone I've told it to. Yet I've never seen anyone tap on them like a pack of cigarettes.
I would guesstimate maybe 10-20% of the filters I've pulled off the rack had metal in them, so there's no way I'm the only one.
Old May 24, 2007 | 01:32 AM
RRT vette's Avatar
RRT vette
Old May 24, 2007 | 02:08 AM
86PACER's Avatar
86PACER
Could the manufacturer(s) face lawsuits for engine damage because of it?
Old May 24, 2007 | 02:27 AM
CentralCoaster
Could. Who will have a better lawyer though? And how would you prove it was contaminated after the fact?
Old May 24, 2007 | 02:31 AM
86PACER's Avatar
86PACER
Is it one particular brand you're finding this on, or random brands?
SK.LT1's Avatar
SK.LT1
Good to know, thanks.
Old May 24, 2007 | 02:42 AM
bogus's Avatar
bogus
I have seen it more commonally on cheaper Frams and such.
Old May 24, 2007 | 05:24 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Fram My favorite filter to hand my buddy when he is changing oil,and he has to race me the next round In the 60's I blew a few of those off my race car and never used one again.
Old May 24, 2007 | 07:02 AM
mseven's Avatar
mseven
I have found similar in alll brands, since I prime all filters first it is just common practice to inspect them. It starts when purchasing, as I have seen some w/rust, adhesive etc. inside them.
Old May 24, 2007 | 07:14 AM
runner140*'s Avatar
runner140*
Good info, thanks.
Old May 24, 2007 | 07:24 AM
Strick's Avatar
Strick
How about using a strong magnet to draw those filings out?
Old May 24, 2007 | 08:07 AM
jimmers's Avatar
jimmers
I never would have thought that. Thanks for the tip!
Old May 24, 2007 | 10:30 AM
N.C. Kid's Avatar
N.C. Kid
They have a crankcase magnet and a oil filter magnet that wraps around the actual filter on the outside. I thought about getting them as its cheap insurance. I have been using frams for a while...
Old May 24, 2007 | 11:09 AM
Aardwolf's Avatar
Aardwolf
I have learned to inspect everything! The best is to inspect it before buying it. Good idea and post! I see the metal in the small holes a lot, the ones around threaded hole. That reminds me of the Holly AFPR that I got, it had metal shavings to. Keep an eye out for that kind of thing!
Old May 24, 2007 | 11:40 AM
KeyWestJack's Avatar
KeyWestJack
Good information.
To Oil filter warning!
Old May 24, 2007 | 11:43 AM
GRX's Avatar
GRX
Good info. Thanks.
Old May 24, 2007 | 12:14 PM
SunCr's Avatar
SunCr
Never seen it, but not surprising - as to who has the better lawyer (and they're not allowed in Small Claims), I onced hired a chemist to prove to Chrysler Marine that I had the right oil mix in my outboard fuel (after it threw a rod). Cost all of $25. I eventually got them to admit that the failure was from an overtorqued rod bolt which was a Line problem they knew about. Plenty of oil engineering firms around, but avoiding the hassle with a little tap makes better sense - especially when you think of how Toyota and GM have dealt with sludge (Toyota oil - GM Dexcool).
Old May 24, 2007 | 12:35 PM
rws.1's Avatar
rws.1
I have never looked for metal shards... thanks for sharing.. I will from now on...
