No start
Old May 24, 2007 | 12:15 PM
TPeye's Avatar
TPeye
Default No start
First, my L98 had a rough hunting idle between 400 and 700rpm. The timing is 10 BTDC, fuel pressure is 34psi, TPS is .54 volts, IAC and oxygen sensor are about a year old, injectors all read 16.4 ohms, there is spark, and there aren't any trouble codes. After disconnecting the battery to reset the ECM the car cranks but will not start. What could be the problem?
Old May 24, 2007 | 12:46 PM
RRT vette's Avatar
RRT vette
Spray some starting fluid in the throttle body while cranking. If it starts and runs with the starting fluid, then you have a fuel delivery problem or the injectors are not recieving the ref pulses from the ECM.
The hunting idle sounds like a vacuum leak. Did you hear any hissing when the idle goes down? What year vette?
Old May 24, 2007 | 03:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I see you have a 90, this info is from my 86, but may help. As RRT stated, try some starting fluid.
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old May 24, 2007 | 05:18 PM
TPeye's Avatar
TPeye
Thanks for the help guys. It is a '90 vette. I got it started after putting the wires in the TPS weatherpak in their proper positions, don't ask. The rough hunting idle is still there, and when making a hard stop it drops to about 400rpm and feels like it is going to stall the way a carburated car would. I checked for vacuum leaks using propane and did not find any.
Old May 24, 2007 | 05:36 PM
RRT vette's Avatar
RRT vette
Just make sure that you have checked and double checked for vac leaks. There are vac lines all over the engine bay. If the runner gaskets are bad, it can cause a vac leak also.
Does it run rich or lean? pulled the plugs lately?
Have you checked your injectors out? Leak down? ohms?
How about the O2 sensor?
Old May 25, 2007 | 03:25 PM
TPeye's Avatar
TPeye
The o2 sensor only has about 3000 miles on it, the plugs looked good (light tan), and the injectors all have 16.4 ohms. I will check again for a vacuum leak, but I will most likely have to bring the car in to have a scanner hooked up.
Old May 25, 2007 | 03:31 PM
rick lambert's Avatar
rick lambert
As suggested, vacumn leak(s), and they can be a mother to find, I've used propane before, some guys prefer other things but it takes a careful diligent check to find them.
Old May 25, 2007 | 03:59 PM
RRT vette's Avatar
RRT vette
As Rick (how are you doing BTW Rick?) suggested, propane is good to use and is how I found my leak. You can also use starting fluid, WD-40, Seafoam in the brake booster, and some have introduced a good bit of smoke into the thottle body to find leaks with good results.
A scan tool will not tell you that you have a vac leak, only show you that a leak is potential depending on the readings. A hunting idle is usually a vacuum leak causing the ECM to contol the IAC motor in and out.
Old Jun 29, 2011 | 10:07 AM
joe paco's Avatar
joe paco
Default old thread, same issue, no start
this thread has some info that might help with the 91 no start problem
joe
Old Jun 30, 2011 | 12:18 AM
jfb's Avatar
jfb
10 degrees BTDC is too far advanced and might be the cause of your idle hunting and hard starting.
Old Jun 30, 2011 | 01:21 AM
Ricky 91 vette's Avatar
Ricky 91 vette
I agree, and I would also do an idle relearn, and try to scan It to check ur counts( I think they should be between 30 to 50 on idle with no ac)
To No start
