Braided fuel line question
Old May 24, 2007 | 03:03 PM
89vette's Avatar
89vette
Default Braided fuel line question
Does anyone know the adapter needed to run braided fuel lines from the fuel filter along the frame rail and return line to an -AN style fitting for a braided hose? I was going to do this once and had the adapters but lost them. I can't remember what is needed. Here is where the braided lines would connect:
Old May 24, 2007 | 11:44 PM
Fatt Vette's Avatar
Fatt Vette
Do you want to retain the factory filter? If so you need a male 16mm X 1.5mm oring to -6AN male such as Russell 648060.
If you plan to eliminate the factory filter and use an aftermarket you should use a female 16mm X 1.5mm oring to -6AN male such as Earls 9894DBJERL.
If your retun line is the same size as the pressure line (and I think it is) use the Russell 648060 there also.
Old May 25, 2007 | 05:42 AM
89vette's Avatar
89vette
I'm going to retain the factory filter. So the Russell fitting with O-Ring fits into the filter and the fitting where the return line connects?
Old May 25, 2007 | 08:56 AM
rodj's Avatar
rodj
Same Russell fitting also does fuel rail end -6AN
Old May 25, 2007 | 08:59 AM
Fatt Vette's Avatar
Fatt Vette
Yes, if both of your lines are 3/8's inch. Or Accel makes a kit p/n 74721 that contains two of those fittings but it is quit a bit more expensive.
Old May 25, 2007 | 09:22 AM
-=Jeff=-'s Avatar
-=Jeff=-
Check here:
http://forums.corvetteforum.com/show...hlight=braided
2 #6 - 16mm x 1.5 O-Ring Seal, 1/pkg.
Part Number # 799-648060
$6.39 $12.78
that is a jeg's PN if I recall correctly
To Braided fuel line question
