Canister Purge Delete
Old May 24, 2007 | 03:50 PM
GRX's Avatar
GRX
Default Canister Purge Delete
I'm thinking about disconnecting the canister line from the engine. Will this throw a code? Anybody not running the canister purge? TIA
Old May 24, 2007 | 04:37 PM
black-LT4's Avatar
black-LT4
It will throw a code on OBDII (1996 and newer) The ECM checks for proper function of the purge canister as this can be a huge polluter if not working correctly
Old May 24, 2007 | 05:48 PM
Road Agent's Avatar
Road Agent
You can ditch it!
Old May 25, 2007 | 11:53 AM
ninetyfivevette's Avatar
ninetyfivevette
Is yours faulty? Besides ridding the compartment of one line, I don't see the benefit. I guess there could be gasoline vapor released into the engine compartment, which is always fun. If that pressure is not released, is just going to accumulate in the tank?
Old May 25, 2007 | 12:05 PM
Aardwolf's Avatar
Aardwolf
I've wondered about that to. How much pressure is there going to be and will it damage anything? I've read posts about plugging the line. Doesn't the system help in a roll over to? I have read posts about leaving the line open, wouldn't gas spill out into the engine making a fire, if you rolled? Removing everything and getting a vented gas cap seems best (very little gas comes out a vented cap compared to an open hose, I've rolled snowmobiles many times) or just keep the system working.
Old May 25, 2007 | 11:42 PM
GRX's Avatar
GRX
Thanks for the info. I'll keep it to avoid problems.
Old May 26, 2007 | 10:24 AM
mseven's Avatar
mseven
I've been considering this so to not have the extra build up on the back of the butterfly and some on the inside of the intake. I was going to use a vented cap. Leave the current line going to cannister from the tank and disconnect it at the top of the cannister and connect it to the bottom line so that leads to the atmosphere.
Plugging it is not a good idea. I think for safety puposes there would need to be a fuel pump/power shut off,(or as in nhra rules of having an external power on -off switch visible) in a roll over situation. If the igniton was on, and car running, the pump would be on, and there would still be line pressure. It would be the available spark or power that could ignite the fuel.
Old May 26, 2007 | 11:03 AM
Aardwolf's Avatar
Aardwolf
When I took mine apart it was super dirty from EGR, I hadn't thought about the evap system putting some there to.
Old May 26, 2007 | 11:29 AM
mseven's Avatar
mseven
I don't believe in eliminating things without reason. Everything on the top end on mine is aftermarket with no other emmisions devices. I think for certain applications if it well thought out it can be accomplished w/out problems.
My reason is that I really don't like seeing all the machined and polished out pieces getting the baked in deposits, especially the back of the TB area. I would imagine everything throughout the intake will aquire deposits including EGR. I might add for others who read this, my experience (lap top is my only passenger) is the cannister purge has no effect on blm, tune etc.
Old May 26, 2007 | 04:30 PM
davemack's Avatar
davemack
Default Vapor canister
No attempt to hijack, but when I run my gas tank low (reserve), I always get a pressure build up that vents when I remove the gas cap. It seems to blow pretty good... Is this indicative of a faulty cannister? Seems like the pressure should be sending the vapors to the canister until they are purged via vacuum into the TB. Sorry again for the intrusion.
Old May 26, 2007 | 04:54 PM
Aardwolf's Avatar
Aardwolf
As far as I know there is no way to tell if the system is OK just from that info. There should be tank pressure, if there was never tank pressure then I would be more worried that it didn't work.
Old May 27, 2007 | 12:20 AM
davemack's Avatar
davemack
Mines probably normal then. I have had an irregular idle and pretty crummy MPG for a while now, so I continue to look for possibilities. It doesn't stall and runs fine on the highway, just not the best at idle. Good thing I spend a heck of a lot less time idling than driving...
Old May 27, 2007 | 12:37 AM
evmlarry's Avatar
evmlarry
This is from my 85 FSM... hope it helps : http://www.larryvhenderson.info/corv...urge_valve.jpg
Old May 27, 2007 | 12:22 PM
davemack's Avatar
davemack
Thanks Larry!
To Canister Purge Delete
