85 TPI build up
Old May 24, 2007 | 05:21 PM
Tigger85's Avatar
Tigger85
Default 85 TPI build up
Hey yall, Im a new and proud owner of a 85 vette, my 1st vette Im excited to start building up the motor, The Tpi motor is original and tired, It really doesnt make much power anymore with 132k miles. Im going to pull the motor and build it up. I have a around 5k to work with. Think I can get about 450+ hp out of it? Id like to upgrade w/o changing the wiring harness. Looking for a good combo for what i have to work with? I sure would like to replace that old intake with like a mini ram and some new heads. Any help or suggestions would be awesome. The car is completly stock.
Old May 24, 2007 | 05:23 PM
Pete K's Avatar
Pete K
You are in luck. What you are looking to do has been done here 100's of times. I built my combo for torque, but many, many good threads about rpm combo's. Use the advanced search feature for days of reading.
Old May 24, 2007 | 05:55 PM
sami85L98's Avatar
sami85L98
5000 is not enough for whole motor though, might be possible but i doubt it, motor+heads+intake and plus tons of small accessories, oh u need to upgrade ur tranny too, may be pete k might help u in that ask him though.
Check my sig for mods, or go to sale section, i listed my combo there. Selling my car.
Old May 24, 2007 | 06:07 PM
pushrod-v8's Avatar
pushrod-v8
stick or auto? if its automatic, then it will fail with 450hp.
Old May 24, 2007 | 06:24 PM
Tigger85's Avatar
Tigger85
Nice combo sami. My trans is an automatic, ill need to upgrade it as well. I have been serching this site looking at all the threads on building a nice combo. Im going to go with 383ci, just trying to figure out what cam, intake, heads that would be that best bang for the buck, and where to order it lol. Honestly id be happy to get 400hp atleast. I would also like to keep the stock wiring harness if it can be done. Thanks for all the info guys.
Old May 24, 2007 | 07:28 PM
bigbob1's Avatar
bigbob1
I would do the tranny first. Especially if it is original. I just did a bunch of mods to the motor on my 85 and blew the transmission about 100 miles later. Nothing like getting your motor dialed in and then not being able to drive it. Just my opinion. Definately talk to Petek about the tranny he will hook you up!
Old May 25, 2007 | 12:17 AM
John A. Marker's Avatar
John A. Marker
Welcome to the Forum and Corvette addiction. 135,000 is not that much for that engine. I have 217,000 on mine currently and still going strong. I would expect the trans to be the first to go.
Check out Vader's web site, it has a wealth of info on engine builds. Suggest that you also practice using the "SEARCH" function (use the advanced option so you can also search archived information. I am currently putting down about 345 HP at the engine with stock cam and pistons and modifications listed below. You could do this within the $5000 if you do the work yourself.
Old May 25, 2007 | 12:46 PM
Tigger85's Avatar
Tigger85
Yeah bud, thx for the info. I do plan to do most of the work myself, I have a friend that will build it, but ill pull and install it.
Old May 25, 2007 | 03:01 PM
pushrod-v8's Avatar
pushrod-v8
the o.e.m. 85 block, crank and rods can handle 450 hp w/o a problem. You can get 400 hp out of a 355 (using stock parts, less pistons...get some forged lighweight j.e. pistons) and get 400 to 450 hp very reliably. Make sure to use APR bolts EVERYWHERE!!!!!!!
Old May 25, 2007 | 10:19 PM
Tigger85's Avatar
Tigger85
Yeah I might just save allot of headache and money going with a 355, my buddy says 383 is the way to go but then ill have to get a new crank and have the block cut to fit it.. what type of cam, intake, and heads should i get to push the 355 to 400+hp?
Old May 25, 2007 | 10:44 PM
pushrod-v8's Avatar
pushrod-v8
Depends on what you want....a long runner tpi style intake can make 400 crank hp and even more flywheel torque. You will need a 52mm throttle body, ported plenum, large tube runners, and a aftermarket base manifold (maybe ported too, maybe not), new heads (go for aluminum), headers, cam (go flat tappet or you will need to purchase a retro hyd. roller cam kit, or get a newer hyd. roller cam block.), headers, cat back, chip, torque converter, and a trans overhaul and some new injectors, valvetrain components, etc, etc, etc. Another solid 400hp manifold is the lpe super ram, although a royal pain in the *** to install.
You can also got 400+ crank horsepower with a miniram, carb type manifold converted for fuel injecton, etc.
Old May 25, 2007 | 10:53 PM
Corvette0096's Avatar
Corvette0096
Your going to need more money..
Old May 25, 2007 | 11:21 PM
edoad's Avatar
edoad
Yes, you will need more money. Besides engine you need a transmission to handle it and a gear ratio to use it. Do "all" the work yourself and don't be skeared of taking things apart and you can do it for not a whole lot more than 5000. Maybe 6 0r 7
Old May 25, 2007 | 11:24 PM
Tigger85's Avatar
Tigger85
Im taking it to the muffler shop tommorrow, should I just take the original cat off? I dont want to replace it and im not worried about emmisions would it help performance allot? Im getting the old mufflers replaced with some flowmasters to start but which kind are best? It sounds horriable right now with it looks like the stock mufflers. Truth of the matter is I bought this car form 52 year old women that owned the car for 16 years, she never did anything to it besides get it painted.
Old May 26, 2007 | 12:26 AM
Tigger85's Avatar
Tigger85
This is the intake im going with, summit part #ACC-74197. Now im trying to decide which runners to go with, arizona speed and marine, accel, or SLP. Which are better ?
To 85 TPI build up
