U-Joint replacement
Old May 24, 2007 | 07:52 PM
davemack's Avatar
davemack
Default U-Joint replacement
I printed out a fabulous half-shaft U-Joint replacement thread here. Almost makes it look easy.
I'm wondering if anyone can tell me how difficult it is to replace the drive shaft U-Joints? I can have the U-Joints replaced at a local shop ($15 for each U-Joint, $15 for each removal/install, $40 to balance each shaft) or I could buy a set of greaseable "heavy duty" U-Joints off eBay for $95, remove/install myself and have the shafts balanced for $200. In either case, I'd have to remove the shafts and carry them in for the rest of the service.
Alternatively, if anyone wants to help/teach me and a buddy how to do it, send me a pm. I'm willing to pay to learn!
Old May 24, 2007 | 08:18 PM
sami85L98's Avatar
sami85L98
davemack, iam doing the u-joint install tomorrow but not me, my mechanic, actually i called a driveline company to balance and install u-joints, 10 to install each u-joint and 75 to balance each half shaft. so the total would be 190+tax, other than my mechanic labor.
But here's an truly excellent info how to install u-joints by Scorp. Thanks scorp for taking ur time and put it on ur website.
http://temp.corvetteforum.net/c4/vader86/
But to be honest i dont think we need to balance half shaft. Others pl chime in : to balance half shaft or not.?
Old May 24, 2007 | 08:24 PM
_twisted_'s Avatar
_twisted_
I just had all mine balanced
Old May 24, 2007 | 08:32 PM
Johngunguy's Avatar
Johngunguy
I just did the U-joints on my LR.
I used Scorps guide for a lot of it as well.
It's not that hard of a job... but then again, I have air tools
Old May 24, 2007 | 09:06 PM
Repzard's Avatar
Repzard
I getting ready to do mine this weekend also and saw the write up scorp did "THANKS SCORP!!!!! .
FYI***I guess Spicer doesnt make U-Joints for our aluminum axles anymore (Part#5-800X)and you dont want to use (part#5-799X) those are for steal drive shaft so reading in another thread I found out that NEAPCO" THANKS TO SERVERE-1" is the way to go and they make a great product " even better than Spicer people claim.
Originally Posted by severe-1
Okay guys, don't hate me....
I had these in my car before I blew the rear and have decided to install them again...
I was told these are what the monster truck guys are running.
http://www.neapco.com/pdf/nov2005_Br...Alumiguard.pdf
Here is the cross reference chart
http://www.neapco.com/pdf/Performanc...ed-9901155.pdf
The very best part is they were $15.00 dollars apiece...
PS...... why do you have to Balance axle shaft I dont see a need for it where they are already balance and if you mark everything the way it came out you shouldnt have any issues IMO.
Repzard
Old May 24, 2007 | 09:14 PM
sami85L98's Avatar
sami85L98
man what shall i say, iam going to install 5-799X tomorrow, what exactly will happen if u install 799X for our Al shafts.
Old May 24, 2007 | 09:26 PM
Repzard's Avatar
Repzard
I think they cant rust quicker and not last as long and you could have problems getting them out the next time you need to replace them.
The ones for the Aluminum Axles have a special coating on caps to prevent rusting.
Im no expert at this but this is what I heard can happen.
Ps...I get a chance I will post a picture so you can see the coating on caps you cant mistake it , its a greyish color and clips are also coated.
Repzard
Old May 24, 2007 | 09:28 PM
sami85L98's Avatar
sami85L98
Originally Posted by Repzard
PS...... why to you have to Balance axle shaft I dont see a need for it where they are already balance and if you mark everything the way it came out you shouldnt have any issues IMO.
Repzard
Its already balanced from factory, 75 for each to balance seems like wasting time and money, let my mechanic install u joints he has special press machine it will be a snap, and i just forget balancing part.
Old May 24, 2007 | 09:31 PM
carriker's Avatar
carriker
I did mine and didn't balance the shafts. No vibrations as far as I can tell.
Old May 24, 2007 | 09:32 PM
ittlfly's Avatar
ittlfly
Just mark the orientation of each shaft to the yoke and you'll be fine.
Old May 24, 2007 | 09:34 PM
Repzard's Avatar
Repzard
Heres the picture
Grey color on caps is the special coating
Repzard
Old May 24, 2007 | 09:36 PM
Repzard's Avatar
Repzard
How long did it take you to do both sides??
Im figuring 3-4 hours.
Does that sound right??
I work on cars all the time so I can wrench
Old May 24, 2007 | 09:50 PM
NotoriousC4's Avatar
NotoriousC4
Unless you had vibration problems before that were related to a verifiable out of balance shaft condition and not just due to shot U-joints, balancing a shaft simply because you're replacing the joints is a total waste of time and money.
Old May 24, 2007 | 09:55 PM
Repzard's Avatar
Repzard
Old May 24, 2007 | 10:17 PM
carriker's Avatar
carriker
Should be shorter than that. I didn't have a vice so I had to take the halfshaft and the new u-joints to a shop to press them in, so I did mine over 2 days off and on. First side should take maybe 1.5 hours, second side maybe an hour. So probably under 3 hours. Good luck, I had fun doing it. But I like **** like that.
Old May 24, 2007 | 10:18 PM
_twisted_'s Avatar
_twisted_
This is not entirely true, if your looking for reliable performance and safety - you do things like this.
FWIW - my d36 DS and H/S's were all balanced (probably at the factory), the d44 shafts I obtained(all from the same vette) were not balanced ever.
The d44 DS wasn't true either it had runout greater than .005
Old May 24, 2007 | 10:21 PM
Repzard's Avatar
Repzard
Me too I figure pull out a axle have a cold one then pull out other axle have a cold one
Thank You for the Good Luck and info
To U-Joint replacement
Old May 24, 2007 | 10:28 PM
Repzard's Avatar
Repzard
Well I guess it up to you if you want to have them balance but I have to with other poster NotoriousC4 if you didnt have issues before and you mark everything you shouldnt have to get them rebalanced IMO.
All you doing is changing U-Joints its not like your replacing the axles itself.
Old May 24, 2007 | 10:53 PM
_twisted_'s Avatar
_twisted_
All you doing ids changing U-Joints its not like your replacing the axles itself.
And that is what I did changed all the shafts
Old May 24, 2007 | 11:15 PM
quiksilver458's Avatar
quiksilver458
I have changed ujoints out on five different c4's over the years. I have never balanced a shaft, and also never experience any vibrations from it. All 15 shafts that i've changed had been balanced prior. I could visually see the weights welded to ends of shafts. I use a large c-clamp, and multiple sockets to press the ujoints out. No problems here. Hardest part for me when changing them out is removing the exhaust. If it has been on there for a while, removing the mufflers is difficult. I now unbolt the rear y-pipe an remove everything together. It is much easier. Good luck with project!
