Hood latch jammed
I am having trouble getting my hood to open. The latch on the left side is jammed. Whenever I pull up on the handle to open the hood the right side opens but not the left side. Is there any way I can manually get the hood to open? Any help would be appreciated.
BTW it is an 85 corvette.
Thanks,
You might have somebody push down on the hood while you pull the lever...if you're lucky it will pop open. Once you get it open make sure the cable is adjusted right and pulls the release mechanism far enough to pop the hood. Also grease the pins and moving parts etc.
GOOD LUCK,
Bosshogg
http://www.geocities.com/bayrunner.g...ml#Hood%20Tool
