vacume line help
Old May 27, 2007 | 08:52 AM
cbarmy04's Avatar
cbarmy04
Default vacume line help
i have a vacume line on the back of my 84 cross fire motor to the left of the distributor on a t valve. it comes from the block to the valve and out the bottom i cant figure out where it go's after it come out the bottom. if any one knows where it go's please let me know. a vacume line diagram whould help to. thankscbarmy04@yahoo.com
Old May 27, 2007 | 09:24 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Not familiar with the 84, but if it's anything like my 86, the vac line from motor goes to check valve/tee then one goes to wire harness at center of firewall (heads to HVAC) and the other line from tee goes to vacuum storage ball in left front fender area. Cruise control would also be fed from this line.
Old May 27, 2007 | 09:58 AM
cbarmy04's Avatar
cbarmy04
thanks i found it it was to the cruse control it just had an adapter to another line on the cruse thingy. sorry for the technical terms im lerning as i go this is my first vett. its an 84 cross fire i got for $2k
To vacume line help
