brake problems
Old Oct 23, 2001 | 04:01 PM
dt35th's Avatar
dt35th
Default brake problems
Keeping the story short, I found that my left front caliper seems to stay locked to the rotor, when car jacked up , you cannot spin the tire, the other side you can spin. Needed brakes so I replaced the brake hoses,had the rotors turned, bought rebuilt calipers and new ebc greenstuff pads. Bled out all the old brake fluid, and I still have the caliper dragging on the rotor, but not as bad. To fully release the caliper you have to open bleeder. NEED HELP......Thanks
Old Oct 23, 2001 | 07:32 PM
dt35th's Avatar
dt35th
Default Re: brake problems (dt35th)
ttt
Old Oct 23, 2001 | 10:26 PM
WEF's 95's Avatar
WEF's 95
I have heard of the inside of the brake hose collapsing and not letting fluid go back toward the master cylinder.
Old Oct 23, 2001 | 10:41 PM
95autoLT1's Avatar
95autoLT1
Default Re: brake problems (WEF's 95)
I have also heard of the hoses going bad but since you already replaced them them I would check the proportioning valve next. There may be a blockage not letting the pressure to be released. :)
To brake problems
