1986 corvette: Won't start
Old May 27, 2007 | 10:25 PM
racerseks's Avatar
racerseks
Default 1986 corvette: Won't start
Can anyone out there give me a bit of a breakdown on what to check, and the most likely order?
The car sits quite a bit. I had it running just last week, and this week I can't get it started.
Here's what I did:
Dash is intermittent, so never sure what the fuel situation is. Put in 5 gallons. No Start.
Tried to jump my battery. No Start.
Used the starting mode on my charger. No Start.
Right now, it's being charged at 10 amps, and ready to try again in a bit.
Basically, my gut feeling is it is fuel-related. It turns over plenty.....just no ignition.
Thanks!
Old May 27, 2007 | 10:27 PM
jfb's Avatar
jfb
Engines require spark and spark at the right time. They also need fuel and air and in the correct ratio to start and run. First check with your timing light during cranking if you have spark and at the right time. Next, put a fuel pressure gauge on the shrader valve on the end of the fuel rail and turn the ign to run for more than 2 seconds and see if you have about 40 psi fuel pressure and notice how long it holds up when you turn off the ign. Rapid pressure drop indicates a possible leaky injector/s causing a too rich condition to start. Next, unplug an injector and connect a noid light (available at parts stores) or use a low power 12v lamp like a side marker lamp across the injector plug. During cranking the lamp should pulse showing the ECM is pulsing the injectors.
Old May 27, 2007 | 10:29 PM
DrEvil11417's Avatar
DrEvil11417
could be fuel.. spark is easy enough to check.. does the fuel pump turn on for a few seconds when you turn the key in the ON position (but not start)?
racerseks's Avatar
racerseks
Originally Posted by jfb
What do you mean by, "no start"? Do you mean that the starter motor cranks the engine but it won't catch and run? Or do you mean the starter does not crank the engine?
Hello.
It cranks, but it will not run.....as if it's not getting fuel or something.
Thanks!
Old May 27, 2007 | 10:30 PM
racerseks's Avatar
racerseks
Hello.
How can I check if the fuel pump turns on?
Thanks!
Old May 27, 2007 | 10:33 PM
jfb's Avatar
jfb
You can hear it run for 2 seconds and shut off. Read my edited response above.
Old May 27, 2007 | 10:38 PM
racerseks's Avatar
racerseks
So that's what that sound is, ha-ha! Yea, I figured that's what it was.....but don't like to assume anything. I figure if I get directions as if I know very little, it is that much less likely I'll overlook anything.....I'll go give it a try.....is it okay to try it with the charger hooked up?
Thanks!
Old May 27, 2007 | 10:39 PM
racerseks's Avatar
racerseks
Thanks!
Nevermind.....I won't crank it.....I'll just turn the key and listen.
Old May 27, 2007 | 10:43 PM
racerseks's Avatar
racerseks
Okay, I heard a familiar hum.....sounds like it's coming from behind me under the floor.....then a click that sounds like it's coming from in front of the dash on the driver's side. Sounds right?
Old May 27, 2007 | 10:59 PM
racerseks's Avatar
racerseks
Also, the battery is charged now, and it still does the same thing. It cranks, but won't catch.
Thanks!
Old May 28, 2007 | 01:10 AM
jfb's Avatar
jfb
The click is the fuel pump relay, the hum is the fuel pump motor. Now follow the diagnostic procedure from my first post so we can isolate the problem. Let us know what you find.
Old May 28, 2007 | 02:11 AM
racerseks's Avatar
racerseks
I sure will. Hoping some auto parts stores will be open tomorrow. Four cars here.....one needs a water pump, and the other two aren't insured or registered.....and got a recent ticket.....so gonna take a nice bike ride. Will let ya know how I make out. Thanks again!
Old May 28, 2007 | 08:33 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
Old May 28, 2007 | 08:43 PM
racerseks's Avatar
racerseks
Thanks for all the help.....here's an update!
Was all set to go get the diagnostic tools recommended here, but decided yo give it one more try.
I checked the fuses last night, but they looked fine. I happend to have a few extra laying around so replaced them anyway. Started first try.
Not sure if it was the fuses, or if it was some sort of security/flood type thing. What do you guys think?
Will let ya know if it doesn't start again, but I tried a couple more times, and seems to be okay now.
This seems to be a common problem from all the posts I've seen.
If anyone if the future has this problem, ya might wanna try replacing your fuses, even if they still look good.....before putting in a new fuel pump or something.
Thank again!
Old May 28, 2007 | 08:58 PM
bill83c4's Avatar
bill83c4
hey race, i don't have much to add but filling out your profile could help if anybody on the forum lives near you could help. i checked your profile to find your location but found none.
good luck man
Old May 28, 2007 | 09:55 PM
AGENT 86's Avatar
AGENT 86
NEVER assume a fuse is good because it looks good. Always use a test light or DMV.
Hope it was just the fuse.
Old Jun 4, 2013 | 11:06 PM
rjs86vette's Avatar
rjs86vette
Cruising
Mine's doing that now (cranking and not remotely catching). I 'looked' at the fuses in that right side panel and they 'looked' fine. (no obvious burn throughs), so we will try replacing / testing all. I think its the a/m alarm system that is causing it to not 'catch' and run. It'll crank, although we think rather stressfully. And we think there is a remote starter installed as well as the a/m alarm. All the prev owner gave me was 2 fobs, and wasnt sure about them. Thanks. E.
Old Jun 4, 2013 | 11:43 PM
vetteoz's Avatar
vetteoz
Originally Posted by rjs86vette
Mine's doing that now.
Might get more attention if you start a new thread fully detailing your problems
http://forums.corvetteforum.com/c4-g...e-or-what.html
To 1986 corvette: Won't start
