Service Engine Soon & Now
Old May 28, 2007 | 02:02 PM
coloradolt4's Avatar
coloradolt4
8th Gear
Default Service Engine Soon & Now
I have a 96 LT4, that doesn't get used very often, but a few weeks ago the Service Engine Soon light came on. I let the fuel level get down to reserve, and then filled it up, thinking maybe after the long winters rest, new gas in the tank would solve the problem. I took it out today, and in addition to the light, I am now getting a noise around the belt/pulley area that sometimes sounds like a bird chirping, and other times more of a continual screech.
I will take it to the chevy dealer tomorrow, but any ideas as to what it might be?
Thanks.
Old May 28, 2007 | 11:49 PM
RRT vette's Avatar
RRT vette
You will have to pull the code with an OBDII diagnostic tool. The SES light means the PCM has seen something/voltage out of it's range. Autozone will pull the code for free. As for the noise, it could be a few things. See if the serp belt is in good shape. You can also take it off and spin the pullys to see if any make noise. Possible a bad bearing.
Old May 28, 2007 | 11:58 PM
Repzard's Avatar
Repzard
Alt could be going causing you SES light." drop in volts"
Like RRT VETTE said a bearing or belt could be slipping do to a bad bearing in Alt.
Good Luck
Old May 29, 2007 | 10:27 AM
coloradolt4
8th Gear
Thanks for the info!
To Service Engine Soon & Now
