95' Headlight Motor Question
Old May 29, 2007 | 03:08 PM
CAJUN C4's Avatar
CAJUN C4
Default 95' Headlight Motor Question
After I turn off the headlight the Motor continues to run for a couple 3-4 seconds after they are down.?
Is this the beginning of a problem?
Old May 29, 2007 | 03:21 PM
MikeC4's Avatar
MikeC4
Your headlight problem is very common to C4's. It is usually the plastic bushing's turning to dust, or the main gear stripping in the motor. I have done this job more times than I care to mention, and it is not hard. With that said, it does take time and patience however. Take a look at this writeup:
http://www.corvettefever.com/howto/33098/
Old May 29, 2007 | 03:34 PM
champ's Avatar
champ
A definite do-it-yourselfer. Change out the bushings in both headlights at the same time. Save yourself the trouble later.
Old May 29, 2007 | 03:44 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Read the C4 TechTips articles in this Forum. It's definitely your Delrin bushings. Get them from Mid America Motorworks (MAM) or Eckler's Corvette Parts catalog.
To 95' Headlight Motor Question
