This problem does not happen until the car has been run around a 1/2 hour or more.When I come to a stop it will start out idleing fine.The idle then starts to go up and down.It will do this a few times before it stumbles and dies.If I hit the gas real quick as soon as it stumbles I can keep it running.If it quits I have to crank it for a few seconds before it will catch.
I have watched the idle air counts before and the count gos up along with the idle.Something is calling for more air when it does this.This is starting to really get to me.The car starts fine,accelerates fine and runs fine except for this idle problem.
Bum O2 sensor maybe? That usually causes an erratic idle. O2 sensor reports a too-lean condition (because it's not putting out as much voltage) and the engine starts to die - so to keep it from doing that, it richens up the mixture and opens the IAC enough - which raises the idle. Repeat until irritated!
Replaced both o2 sensors.Still doing the same thing.I thought it may be a vac leak but it is idleing fine before it speeds up.The idle air steps stay at arount 20 and then jump up to 35 or 40.The motor is idleing smooth when it does this.The integration values stay pretty steady during this as well.
Hi I disconnected the iac motor when it started to speed up and down.I drove it a few miles until it got good and hot and it seemed to idle fine.It did not stumble or surge any.Could the iac valve be bad causing this on its own.
This happened to me a couple of years ago- it was bad gas- if you recently switched brands or are not using premium- try going back to what you were using before
