1989 strumbling when hot with no code
Old May 30, 2007 | 08:00 AM
philou's Avatar
philou
Default 1989 strumbling when hot with no code
Hi,
1st excuse for my bad english
My Vette is a 1989 AT.
When the engine is cold it's ok.
After 40miles my engine strumbles and could stall if I drive slowly.
SES is lighting when it strumbles but there is no code except 12.
As the SES is lighting, the fuel consommation is blocked (dash board indication)
I put these new parts:
-pick up coil
-fuel pump
-fuel filter
-sparks
-cool temp sensor
Thank you for your assistance
Old May 30, 2007 | 08:45 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you 100% sure there is no stored code ??
Do you have access to data logging laptop or scanner.
Is the oxygen sensor working ??
Old May 30, 2007 | 09:27 AM
Casethecorvetteman's Avatar
Casethecorvetteman
First thing to do is stop replacing good parts, and start testing what youre pulling out before you replace it.
Next thing to do is get the igniton control module tested.
Then check all the wiring to all the sensors. Check the AIR system while youre at it.
This stumble will be probably either fuel or spark, if you can get 40 miles before it occurs id guess at spark and look to ignition control module.
Old May 30, 2007 | 09:38 AM
Cain91's Avatar
Cain91
Mine was doing the same thing and 4 of my fuel injectors were shorting out. Check the ohm readings all should be in the 16-17 ohm range. Check cool and then again when warm also. My car was getting to much fuel when in closed loop and running rich. Technically it still as as I haven't replaced the injectors yet.
Old May 30, 2007 | 09:44 AM
philou's Avatar
philou
No code stored (A+B connections): That's the problem !
EGR is disable with this:http://cgi.ebay.com/ebaymotors/86-89...spagenameZWDVW
but my engine had the default before I put it.
Thank U
Old May 30, 2007 | 09:51 AM
philou's Avatar
philou
HEI is new to...
Old May 30, 2007 | 09:53 AM
philou's Avatar
philou
OK, thank you for all
I keep contact
Philou
Old May 30, 2007 | 09:56 AM
Casethecorvetteman
Originally Posted by philou
HEI is new to...
Is the ignition control module new? That isnt included with the HEI distributor as far as i know
Old May 30, 2007 | 10:26 AM
philou's Avatar
philou
new Distributor Ignition Pickup
new Starter Solenoid
new Control Module
new Distribution Cap and Rotor kit
new Ignition Control Module
Old May 30, 2007 | 10:38 AM
Casethecorvetteman
Might have to start going through all the wiring and making sure its all nice and firm, sounds like its going to be one of those simple little things that is a ***** to track down.
Old May 30, 2007 | 10:44 AM
rick lambert's Avatar
rick lambert
I'd be doing a fuel pressure test while driving, to see if the pressure dropped when the stumbling occured. Next, as suggested ohm those injectors.
Old May 30, 2007 | 12:03 PM
philou's Avatar
philou
I have mounted a LT1 fuel pump because old was bad when hot
cold engine with my old TPi pump at 700rpm: 32 psi
hot engine with my old TPi pump while accelerating : 26 psi
But I have always the bug.
You're right, 1st I must see the presure when stumbling occured.
Old May 30, 2007 | 12:06 PM
philou's Avatar
philou
It's the charm of the TPi
Old May 30, 2007 | 01:49 PM
RRT vette's Avatar
RRT vette
Time to test things that will no cause a code. Fuel pressure (especially when the demand on the pump is highest), injectors (ohm hot and cold, also fuel pressure leakdown), ICM and pickup coil, FPR, spark plug check and ohm plug wires, check the connections on all engine function sensors and the above mentioned.
New parts can fail too.
Old May 31, 2007 | 10:55 AM
philou's Avatar
philou
Oh yes but if one cannot have confidence any more in new parts...
I order to Rockauto: it's more easy from FRANCE.
Old May 31, 2007 | 11:49 AM
Casethecorvetteman
One cant, one needs to test the parts in question in order to be confident in their function
Old Jun 1, 2007 | 11:18 AM
philou's Avatar
philou
You're right
To 1989 strumbling when hot with no code
Old Jun 1, 2007 | 11:48 AM
Casethecorvetteman
No worries mate
Old Jun 1, 2007 | 06:25 PM
Sam Lam's Avatar
Sam Lam
I would bet a six pack of good beer that his injectors are starting to crap out due to shorted turns in the coils. This is so easy to check too! Spec is 16.5 +/-.3 ohms. All eight should be very close to the same value.
philou: let us know what you find to be the problem.
Old Jun 1, 2007 | 07:57 PM
philou's Avatar
philou
I wonder why injectors are bad after 30-40miles (or 1 hour) and not at cold engine...
So no problemo, I keep contact with the forum. As soon as I find my bug, I post it
