MSD-Tach connection
Old May 31, 2007 | 05:53 AM
ozcar's Avatar
ozcar
5th Gear
Default MSD-Tach connection
Hi, I'm just about to complete a carb conversion on a 383 L98. I'm not sure of how to connect the tach to the MSD. I am using a pro billet distributor and a 6AL. Does the tach output from the 6AL connect staright into the tach signal wire in the dash. I have had the 6AL for a while and don't have the wiring diagrams.
Old May 31, 2007 | 07:27 AM
shop14's Avatar
shop14
use the 6al tach output,tach wire to the msd and you should be fine
