I can think of three logical places to put a sensor for an electric transmission temperature gauge:
1) Make a hole in the side of the pan and braze a fitting in place -- can also be used to drain the transmission.
2) Install it in the line-pressure port.
3) Install it in a fitting in the cooler line.
I don't like number 3 because it would read the temperature of the cooled fluid which is probably cooler than the transmission.
For number 2, I'm not sure if the sensor, protruding into the port, would cause any blockage of the line-pressure fluid flowing by -- or is this a blind hole?
And, because the fluid is under high pressure, it probably will be hotter than the rest of the transmission.
I'm thinking that option 1 would make the most sense because it would give a more average temperature reading.
I use the line pressure port with no problems, but I don't know how accurate it is.
Even if it's not that accurate, it will still give you a reference point so that you can see an unusually high reading.
Hope this helps.
I used a trans. drain plug kit, left the plug out, and put the gauge sender in it's place. I used the drivers side forward part of the pan. It only took a few min. to install. You have to check carefully for room, there are many moving parts. The gauge is working great for me, it measures the pan temp. From what I have read, output temp. is usually 30° more. I will snap some pictures this weekend.
Later year C4's do have the trans gauge but I do not know where the sender is. On my year the drivers side forward part of the pan was nice. There is nothing in the way, it's not to close to the exhaust, and the pan was still flat there. A lot of pan is rounded and would be tough to seal with the drain kit. If I remember right the 11/32 drill bit was perfect for the drain plug kit, the mount actually threaded in slightly in that size hole. I have a bunch of projects going on, I'll take a few pics and include the sender location.
On the radiator I used -6 an fittings, one is an inverted flare to AN adapter and the other is a 90° bend. Then just ran hose and clamps.
Instead of buying a guage kit and finding a place to put it, Go get a stock oil temp sender for the engine, get a 2 position toggle switch and wire it into your stock digital guage, splice the switch into the wire going to the stock sensor, make sure you solder and heat shrink the connection install the switch where you like it. Do like the guy said put a welded fitting on your pan the next time you change the fluid and filter. Once this is done it will be a great place to drain the oil for easier maintenance.
The drain plug kit with the sender in it still works fine to drain the ATF, you just remove the sender instead of the plug. Neat idea with the stock oil temp. sender! I track mine though and need to be able to glance at gauges, I do not have time to flip switches. The aftermarket gauge also has a warning temp. that you can set. The drain kit was $6 and the gauge was $50 if I remember right. Coming off the drivers front of the pan, the wire comes in the cabin by the battery, there is a rubber boot there and it was very easy to bring a wire in there.
??? For a gauge sending unit???
I posted that very idea, ages ago. That is what I am doing. I'm just trying to decide if there is a better place for the sender than the pan. I doubt it.
