Hello - My forst post on here and I have a real interesting situation. I am getting a rattling over bumps which is coming from the passenger dash, behind (above?) the fuse panel area. I can not locate the actual item rattling, I had the glove box out and the lower dash panel out and I could not figure it out.
When I went for a drive, I had the glove box removed along with the light disconnected (for the glovebox) and after getting back I noticed when I opened the door (keys out) there was a warning buzzer. Not the "ding ding" like when the keys are in the ignition, or when the lights are left on, but a buzzer. it seems to be coming from the passenger vent area and only comes on when the door is open. Even with the key out.
So I have 2 annoying noises coming from the passenger area, can anyone suggest some fixes, or steer me in the right direction?
I cannot help with the Rattle, BUT, the BUZZ is the relay/timer that shuts the lights off after X seconds. If you look in your fuse panel there are 2 fuses for interior lights. 1 of them is blown, I cannot remember exactly but 1 is like 5 amps and the other is like 20. I do not remember which 1 causes the buzz either.
First, let me welcome you to the Forum. Secondly, let me apologize for not knowing how to remedy your particular situation. Thirdly, let me respectfully suggest that you fill out the details of your profile. Au Revoir
