I need a new shift **** for a 6 speed and would like to look for an OEM part before I check out the aftermarket.Are the ***** the same for all ZF 6 speeds,Thanks.
I tried the above link and it wont work,somebody has the number Im looking for.
It's not a link, it's an actual PDF file. Left-click on it and choose open. If you have Adobe Acrobat Reader installed on your PC, it should open it up for you and you can print it or save it. If you don't have it, it's a free download...
The most current production part # 10224091 is a replacement for all ZF 6-speeds '90 thru '96. The PDF shows a part number for '90 thru '92 but it was replaced in '94 with the current number. I don't know about the '89 **** but I'm quite sure the later works. You just need to match the insert with the ****. That does NOT include the insert or the pin that secures it.
I'd post in the wanted/for sale section and try to find a "very good" one vs. a new from GM. It's quite expensive. I may have a couple Hurst ***** with the pattern on them but not an OE leather ****. I like the feel of the Hurst, it's a quite good sized ****.
