Ground Problem?
Code: H21 (TPS)
Voltage reading way low (.32 - 3.7) although the book says code 21 is voltage too high?? Inspected (accessable) wiring to PCM, all look fine. Replaced TPS w/new.....same low reading.
Wiper ground problem as well. Had to ground it out (ground wire to block) in order to work.
Also, Cruise Control not working, although have yet to diagnose that.
This all happened suddenly after a 4 month storage. (everything worked last fall and TPS was at .54 idle) So, I suspect a ground issue in my PCM? Checked/cleaned all the 'known' grounds (7 wire bundle from harness to engine) as well as ground strap from chassis to block.
All to no avail. Still pulling code 21, still failing sniffer (high HC's - rich) still seems to run excellent.
Any suggestions?
