Ignition Module Circuit
Old Jun 4, 2007 | 04:16 PM
topspin's Avatar
topspin
Default Ignition Module Circuit
On a 96 Lt-1, If you unplug the ignition module and check the ground wire ( blk/wht ), what should your ohm readings be with ignition switch on and with it off ? Mine is showing a good ground with key off but also showing grounded with key on. I feel this is grounding out my ign mod circuit and mt coil will not fire. I have voltage at pins A and D, also I do not have AC voltage at the white wire with key in cranking position. I also checked the wires leading to the opti/dist and got the 5 volts which were suppose to be there. I beleive I'm missing the pulse coming from the opti going to the pcm. Could the ign mod circuit being grouded with the key cranking be causing my problem ?
