$2000 To Spend
Old Jun 4, 2007 | 05:10 PM
Novakid's Avatar
Novakid
Default $2000 To Spend
Well I have saved up about $2000 to drop into my 88 L98 A4. The first thing that I would like to do is put a nice lopey cam into it, and probably RR's. I really dont have a great idea how much this type of thing costs. Is it realistic that I could get a new cam and 1.6 RR's for 2k installed? Also, what kind of HP gain could one expect from those two mods?
Thanks in advance
Old Jun 4, 2007 | 05:40 PM
Aardwolf's Avatar
Aardwolf
Are you going to do more mods in the future? I don't know if you would gain a ton because the stock intake and exhaust is pretty bad and would limit the effectiveness of the cam. Someone else can chime in with a HP number.
Valve train parts can open a can of worms. If you put rockers on it's best to change the springs and valve seals. You cannot run a big cam without changing the springs. Putting a new cam in, a new timing chain would be good, possibly dampner to. You would need new lifters with a new cam, those are pricey.
Just the rocker upgrade would be OK then switch to exhaust or intake. There have recently been many threads on the rockers, run a search.
Old Jun 4, 2007 | 06:36 PM
steven mack's Avatar
steven mack
A set off Brodix IK heads Comp Cams xfi cam and good cat back exhaust could be had for 2000$ that would give you a nice bump in power.
Old Jun 4, 2007 | 07:26 PM
MFS's Avatar
MFS
Heads, intake and headers would be my choice. A cam and rockers will not help much if you can not get the air in and the exhaust out.
Old Jun 4, 2007 | 07:28 PM
wingman4rent's Avatar
wingman4rent
Headers, y pipe, high flow cat, and good rear exhaust, and there goes about 2 grand.
Old Jun 5, 2007 | 12:38 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Agree:
TPIS headers & Y-pipe: $1200
Magnaflow exhaust w/hi-flow Cat: $600
Balance: parts needed
there ya go $2000...
and a great start....those items were just to show you $2K doesn't go very far....
Old Jun 5, 2007 | 01:16 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
He wants to pay someone else to install the parts. So divide that $2K by 3 and go from there.
Old Jun 5, 2007 | 11:01 AM
rickneworleansla's Avatar
rickneworleansla
You could get your heads professionally porterd along with a custom cam for under $2k but that doesn't include labor and many other parts that will probably be needed along the way. I started adding up parts for my heads and cam install and got over $4k and still adding. That's not including that forged bottom end that I really want. As usual, I'm probably going overboard on a few things. I'm buying a piece at a time. By the time I have everything I may be ready for a new engine anyways. You could get a complete nitrous system for under $2k installed. That would be the most hp for your $. Like the others suggested you may want to start with the exhaust and headers though.
Old Jun 5, 2007 | 11:23 AM
MikeyT84's Avatar
MikeyT84
I'm looking to sell my Fastburn Heads and Hotcam if your interested in that, PM if you want
Old Jun 5, 2007 | 02:25 PM
N.C. Kid's Avatar
N.C. Kid
Possiblly cheap?
To $2000 To Spend
