Header users beware!
Old Jun 5, 2007 | 09:53 PM
The Beep's Avatar
The Beep
Default Header users beware!
The heater box control failed on my 85. I presumed it was do to a mouse raising havoc behind the dash. After looking everywhere for the problem, I decided to wave the white flag, bend over and bring it in to the stealership.
After nearly 5 hours, the mechanic was ready to give up when he found a tee junction that wasn't shown in the schematic. That directed him under the right side rear header pipe where a harness with the vacume hose and what appeared to be fuseable link had burned through.
He repaired the hose ($680 all labor).
That area still looks dicey. I would like to somehow reroute that harness away from the headers beacuse fuseable link + oil + headers = fire.
Old Jun 5, 2007 | 10:00 PM
Demonic85's Avatar
Demonic85
Do you have pictures of the wiring?
Old Jun 5, 2007 | 10:17 PM
The Beep's Avatar
The Beep
No, and there's very little room to get a camera or hands or anything in there. If you look between the 2 rear pipes on the right side, you'll see the cooling fan temp switch (this is on an 85 now) and the harness runs just below it so it's between the headers and the motor. A horrible place for stuff like that don't you think?
Old Jun 5, 2007 | 10:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I know of no vacuum hose where you are describing. Did they lube you first??
Old Jun 5, 2007 | 10:46 PM
The Beep's Avatar
The Beep
I am no fool. I looked under the car at the stealership and saw first hand what the mechanic was talking about before he made the repair.
There are 3 reasons you don't know this: 1. You don't know everything. 2. It's not in the GM schematic. 3. It may be due to some modification from who knows when for who knows why.
Old Jun 5, 2007 | 10:54 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I wonder if thats the plastic vacuum hose for the hvac system.It runs through with the wireharness into the car through the firewall junction,near where you said it was.When that hose breaks,melts,the vents for the heat or air dont work properly.
I fixed these on other GM cars before.I do not know if someone rerouted your lines or wires too close to the exhaust system.But the tube usually runs in back top of the engine into the wireharness loom,then through the firewall.
Old Jun 5, 2007 | 11:04 PM
Demonic85's Avatar
Demonic85
woah, a bit touchy arent we? I know what wiring you were talking about I was just wondering how they fixed it. Not all years have the same wiring and vacuum lines.
Old Jun 5, 2007 | 11:32 PM
AGENT 86's Avatar
AGENT 86
Old Jun 5, 2007 | 11:59 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'd be touchy too after trying to psychologically justify giving the mechanic $680 to get touchy with me.
All of those dampers are vacuum actuated. That sounds like possibly the main vacuum source to the whole heater box. If moving the levers in the car causes big sucking noises, that hose should be one of the first things he looks at. But I'm guessing he tore the whole dash apart first. This is akin to removing your volt guage to find out why the battery voltage is low.
My hindsight is 20/20.
Old Jun 6, 2007 | 12:03 AM
The Beep's Avatar
The Beep
Do you need more universal health care? Why is this so baffleing to you? I described exactly where the harness is. It's probably the same on your 86. If your not aware of it's presence, your beautiful yellow car may turn black someday. It might be worth sticking your nose in there and having a look don't ya think?
Old Jun 6, 2007 | 12:12 AM
The Beep's Avatar
The Beep
Sorry, it's been a very bad week for me and snide remarks arn't sitting very well.
Bed-time. Tomorrow will be a better day. Good nite.
Old Jun 6, 2007 | 08:10 AM
AGENT 86's Avatar
AGENT 86
I'm not trying to be a dick, it just sounds like the dealer screwed you. The vacuum line that feeds my HVAC goes into the wire harness behind distributor and then through the firewall near the middle. Iv'e built my own motor and installed my own headers and know of no vacuum line down by the passenger header. That's why a pic might shed some light.
Old Jun 6, 2007 | 08:55 AM
LD85's Avatar
LD85
I dont have any wires to my HVAC running close to my headers, I might have re-routed them over the top of the box when I put the headers on.
$600 is crazy, but thats what the stealerships charge, I'm sure that you knew you were gonna get tagged, but obviously you need to reroute your harness asap.
Old Jun 6, 2007 | 08:58 AM
85vet's Avatar
85vet
Cruise-In V Veteran
I am sure I know what you are talking about. the vacuum line does go into the harness behind engine & pops back out and goes to an area near the bottom of the blower box.
I have all wires that come withen 6" of the headers covered with heat tape to protect them.
Interesting post - headers = heat, heat = damage if not managed.
Old Jun 6, 2007 | 10:03 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default Coated headers?
Are your headers coated or wrapped with header wrap? If not do it... I used to post very often on the damage uncoated headers were inflicting on my 94. Bottom line was I coated the headers and it solved everything. Of course, I had to make sure nothing was within a few inches of the headers as an abundance of caution... Take them off and ship them to Jet-Hot or similar coater... Problem solved!
Old Jun 6, 2007 | 10:31 AM
jmrl98's Avatar
jmrl98
Sounds like a decent heads up - I'll be checking the wiring around all parts of my headers today.....
Old Jun 6, 2007 | 11:35 AM
CFI-EFI's Avatar
CFI-EFI
That is what dealers DO! You know THAT going in.
There is another plastic vacuum line that passes through the firewall to the right of the engine that operates the heater water control valve.
RACE ON!!!
To Header users beware!
Old Jun 6, 2007 | 11:53 AM
rickneworleansla's Avatar
rickneworleansla
How much of a difference does the coating make in temp before and after? My headers are coated and still get very hot. Enough to burn through one of my wire boots that was touching. They do cool down way faster, quick enough to touch after about 10 minutes. What type of problems were you having? Was it just the heat that was radiating out? I guess since mine have always been coated maybe I don't realize how much worse it could be non-coated. I am still very happy with my headers.
Old Jun 6, 2007 | 12:18 PM
jakers's Avatar
jakers
St. Jude Donor '06
I never measured the temps but I can tell you it is dramatic! The uncoated headers melted everthing within 6 inches... and when I drove the car with the uncoated headers I would come home and lift the hood to vent the heat. In the summer it would take close to 2 hours before you could touch the headers... Now I can drive it home and work around the headers in 20 -30 minutes and not get burned.
Even coated I am careful to keep things away from the headers. The rule here is ZERO contact with the headers! I took alot of time to make sure things are routed
Old Jun 6, 2007 | 12:36 PM
ittybittyfds's Avatar
ittybittyfds
i am curious about this myself..after my headers were installed the mechanic told me that there is a harness on the passenger side that is a couple of inches away from the header and he recommended that i header tape the harness.....i still do not see what he was refurring to but this post has me wondering now....i better look better
Thanks BEEP
