Fuel Question?
Old Oct 25, 2001 | 12:11 AM
R23HTC's Avatar
R23HTC
Default Fuel Question?
As you can see from the sig the motor has had it. It's going to take much longer than I expected before I can get it in to get it rebuilt. (money) At this point it's unknown. At least till after the first of the year, when the tax refund gets here to help out. My question is, is there anything I should do?. It has close to a full tank of gas. I start it just enough to keep the battery from going dead. I don't want to disconnect it as it sits outside of my apartment, under a car cover, and I want the alarm to work. I drove it around the complex, basicly at idle (man I can't stand the sound this poor motor is making) to take some rust off the rotors and help keep the tires from flat spotting. Any other suggestions???????? Opinions????
[Modified by R94 LT 1, 10:13 PM 10/24/2001]
Old Oct 25, 2001 | 01:38 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Fuel Question? (R94 LT 1)
Honestly, the best thing is to rent a storage unit and put it on jack stands. Sounds like you are already doing really all you can. When the weather starts to ice, make sure that tank is full.
Old Oct 25, 2001 | 01:42 PM
R23HTC's Avatar
R23HTC
Default Re: Fuel Question? (Vette92)
I know that would probably be best, but at close to $200 a month that's subtracting from the motor rebuilding budget to fast. I'd rather keep doing this unless it's doing more damage than it's worth.
I guess what I left out of the original question was whether or not to add a fuel stabilzer or something, or just have the tank drained when I have the motor done?
Old Oct 25, 2001 | 01:46 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
I agree with Vette92. If you live in that bad a section of town that you're willing to drive around on a broken engine just to keep the battery alive for the alarm, then storage really is the only other option. When You put it away put the battery on a trickle charger. As long as you have a full tank of gas that should be ok if the car will be out by Spring.
-John
Old Oct 25, 2001 | 01:49 PM
War Machine
...at close to $200 a month .... :eek: :eek:
You can't find anything cheaper? I thought Il. was expensive! :U
Old Oct 25, 2001 | 04:51 PM
R23HTC's Avatar
R23HTC
Default Re: Fuel Question? (War Machine)
-John
It's not that it's such a bad part of town. It just helps to keep the kids away from it! I've got enough scratches from bikes and scooters on the Malibu. I don't need them on the Vette too!
To Fuel Question?
