95 LT-1 OBD1/OBD2 Scan Tool Please Advise THX!!
Hello, due to the support of Corvette Forum members (thank you everybody) I've decided to purchase a scanner and do dynamic testing on my own vehicle while idling and driving-there may be a bad sensor connector, etc., and the dealer is just throwing parts at it to no avail. I have two in mind: The ACTRON CP9190, which I was told would pick up 20 parameters, or the OTC SCAN PRO 3499, which is supposed to pick up over 100 parameters. This is a 1995 (hybrid OBD1/OBD2) but has the OBD2 connector underdash. Anybody have any experience with either of these scanners or any recommedations? I'm mechanically inclined but not an expert-and I cannot afford a TECH II scanner. Forget the dealer-I'm done with them ($$$) and they "can't fix it" Thanks!!
hybrid, huh? Im not sure that is possible, I know some late 95's were obd2, but the rest were ones. I would try on ebay and see if you find something on there, I got my scantool for $60 shipped.
So when did they change the 95's to OBDII. My understanding was all had OBDI with OBDII DLC. The shop that helps me uses a Snap-on scanner. http://buy1.snapon.com/products/diag...IN&dir=catalog
Not one single late 95 was OBD2. They are all OBD1. 96 models are OBD2, and were manufactured in the last half of 95, but they are NOT 95 models, they are 96 models. There is no half breeds.
The reference to hybrid OBD he is refering to is cause 94 and 95 also have some OBD2 codes, however the system is OBD1. Its all in the service manual, and a TECH 1 might be the better unit to buy. (you dont need a TECH 2, TECH 1 will do everything you need on a 95)
That is correct-the vehicle DOES from what I have been told have some OBD II codes and has an OBD II connector underdash, but essentially is an OBD I car......and is a late build 95. I want to buy a good hand held scanner to diagnose it myself. THX!!
Use a Laptop and Data Master mate, it will do all you need to do as far as showing sensor info, if you really feel the need for a scanner, look into getting a TECH 1.
If DTC retrieval is all youre after, get yourself a paper clip and follow the procedure below....
On a 94/95 you can check the codes with a paper clip as follows:
You short pin "12" to pin "4" and turn the ignition switch to "On" without starting the engine.
The speedometer will display any codes using the same protocol as the 1990-1993 model but there are some changes in the designation for the modules plus additional modules are added:
Module "1" is still the CCM module.
Module "4" is now called the PCM module (Powertrain Control Module) because automatic transmission computer control was added to Engine Control Module in 1994.
Module 7 (on the 1996 model only) is the RTD module. (This is the Real Time Dampening module which replaced the Selective Ride Control module in 1996).
Module 9 is the ABS/ASR module number from 1994 through 1996.
Finally, Module "A", the DERM (Dynamic Energy Control Module --- (the air bag control module) will be requested to show any codes.
Just like the 1990-1993 display, you read the codes on the speedometer (big) and read the module number on the trip odometer (small).
A series of dashed lines for instance “ - - -“ indicates no more stored codes for that module.
A code showing as “C12” for the CCM module (module #1) means no codes are stored. So C12 is a good thing to see.
Again, you can cause the codes to repeat by turning the ignition off for five seconds and then back on.
Turn the ignition off and remove the short to restore normal operation.
To clear the codes,
1. With ignition "off" ground terminal #12 of the DLC (use bent paper clip to connect pin 4 to pin 12)
2. Turn ignition "on".
3. Press trip/odo button on the DIC until 1.7 appears in the trip
monitor area of the instrument cluster.
4. Press eng/met button on the DIC & hold until "---" appears in the
speedometer area of the cluster, this will clear CCM DTC'S.
To clear PCM/ECM codes do the following:
1. Press the trip reset button on the DIC until the desired system is displayed. In this case it will be 4.0.
2. Press trip/odo button on the DIC until the desired diagnostic mode(4.7) is displayed on the trip monitor area of the cluster.
3. Press & hold the eng/met button on the DIC until "---" is
displayed in the speedometer area of the cluster, this will clear PCM codes.
To clear ABS/ASR codes do the following:
Same as above but you’re looking for “9.7” on the trip odo
And here are the codes
1994-1995: Diagnostic Trouble Codes
DTC #11: Malfunction Indicator Lamp Circuit.
DTC #13: Bank #1 Heated Oxygen Sensor #1 Circuit:
DTC #14: Engine Coolant Temperature Sensor Circuit Voltage Low.
DTC #15: Engine Coolant Temperature Sensor Circuit Voltage High.
DTC #16: Distributor Ignition System Low Pulse.
DTC #18: Injector Circuit.
DTC #21: Throttle Position Sensor Circuit Voltage High.
DTC #22: Throttle Position Sensor Circuit Voltage Low.
DTC #23: Intake Temperature Sensor Circuit Voltage High.
DTC #24: Vehicle Speed Sensor Circuit.
DTC #25: Intake Air Temperature Sensor Circuit Voltage Low.
DTC #26: Evaporative Emission Canister Purge Solenoid Valve Circuit.
DTC #27: EGR Vacuum Control Signal Solenoid Valve Circuit.
DTC #28: Transmission Range Pressure Switch Assembly Fault.
DTC #29: Secondary Air Injection Pump Circuit.
DTC #32: Exhaust Gas Recalculation.
DTC #33: Manifold Absolute Pressure Sensor Circuit High.
DTC #34: Manifold Absolute Pressure Sensor Circuit Low.
DTC #36: Distributor Ignition System High Pulse.
DTC #37: Brake Switch Stuck On.
DTC #38: Brake Switch Stuck Off.
DTC #41: Ignition Control Circuit Open.
DTC #42: Ignition Control Circuit Shorted.
DTC #43: Knock Sensor Circuit.
DTC #44: Bank 1 LF Heated Oxygen Sensor #1 Circuit Lean.
DTC #45: Bank 1 LF Heated Oxygen Sensor #1 Circuit Rich.
DTC #47: Knock Sensor Circuit Or Module Missing.
DTC #48: Mass Air Flow Sensor Circuit.
DTC #50: System Voltage Low.
DTC #51: EPROM Programming Error.
DTC #52: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #53: System Voltage Low.
DTC #55: Fuel Lean Monitor.
DTC #58: Transmission Fluid Temperature Sensor Circuit Low.
DTC #59: Transmission Fluid Temperature Sensor Circuit High.
DTC #62: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #63: Bank 2 RF Heated Oxygen Sensor #1 Circuit Open.
DTC #64: Bank 2 RF Heated Oxygen Sensor #1 Circuit Lean.
DTC #65: Bank 2 RF Heated Oxygen Sensor #1 Circuit Rich.
DTC #66: A/C Refrigerant Pressure Sensor Circuit Open.
DTC #67: A/C Pressure Sensor Circuit Sensor or A/C Clutch.
DTC #68: A/C Relay Circuit.
DTC #69: A /C Clutch Circuit.
DTC #70: A/C Clutch Relay Driver Circuit.
DTC #72: Vehicle Speed Sensor Loss.
DTC #73: Pressure Control Solenoid Circuit Current Error.
DTC #74: Traction Control System Circuit Low.
DTC #75: Transmission System Voltage Low
DTC #77: Primary Cooling Fan Relay Control Circuit.
DTC #78: Secondary Cooling Fan Relay Control Circuit.
DTC #79: Transmission Fluid Overtemp.
DTC #80: Transmission Component Slipping.
DTC #81: Transmission 2-3 Shift Solenoid Circuit.
DTC #82: Transmission 1-2 Shift Solenoid Circuit.
DTC #83: Torque Converter Solenoid Voltage High.
DTC #84: 3-2 Control Solenoid Circuit.(Auto Only).
DTC #84: 2nd And 3rd Gear Blockout Relay Control Circuit.
DTC #85: Transmission TCC Stock On.
DTC #90: Transmission TCC Solenoid Circuit.
DTC #91: One To Four Upshift Lamp(Manual Only).
DTC #97: VSS Output Circuit.
DTC #98: Tachometer Output Signal Voltage Wrong.
To clear the codes,
95 Scan tool
Hello,
She's not throwing any codes at all-just has a rotten egg/sulphur/sour exhaust smell and the dealership threw every kind of part at it you could imagine and said NOTHING is wrong with it. We're figuring most likely a bad sensor connector somewhere or perhaps a problem with an injector. Lots of $$$ have been spent and everything has been replaced including the CATS, O2 sensors, etc., etc. The vehicle DOES from what I have been told have some OBD II codes and has an OBD II connector underdash, but essentially is an OBD I car......and is a late build 95. I want to buy a good hand held scanner to diagnose it myself. THX!!
