what dose code mean
Old Jun 12, 2007 | 11:03 AM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by imp65409
Since you may not have the money for the Helms manual I would suggest you get the Haynes corvette manual at Autozone. I think the manual is like $20.
Bad advice. For anyone that plans to keep and work on their car, the Haynes, Chilton or any other generic manual is sorely lacking. The generics may show how to set the TPS, but they don't have the trouble shooting charts to find the cause of a code without throwing parts and money at the problem. A $20.00 substitute only delays the inevitable and adds to the cost. Save the $20.00, go straight to the source, and buy a FACTORY SERVICE MANUAL.
RACE ON!!!
Old Jun 12, 2007 | 11:57 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Totally.
Old Jun 12, 2007 | 01:00 PM
cbarmy04's Avatar
cbarmy04
ok ill get 1 as soon as i get the money. thanks for the help
Old Jun 12, 2007 | 02:17 PM
staugur's Avatar
staugur
You may want to think about an adjustable TPS rather than the fixed one.Not much difference moneywise.
Old Jun 12, 2007 | 02:18 PM
cindymajolie's Avatar
cindymajolie
4th Gear
http://www.pink-martini.org/missions...rMeOJ7Lhf6Vu5L
Old Jun 13, 2007 | 02:45 AM
imp65409's Avatar
imp65409
I agree that the FSM is the only way to go. I agree that the other manuals are lacking info. But since he stated that he does not have the money for the fsm....he is left with little choice. If he had the money for the FSM then by all means use it. just trying to help the guy out. Dave
Old Jun 13, 2007 | 11:46 AM
CFI-EFI's Avatar
CFI-EFI
HUH???
How do you NOT buy an adjustable TPS for a 1989 and earlier C4?
RACE ON!!!
Old Jun 13, 2007 | 11:52 AM
CFI-EFI's Avatar
CFI-EFI
I'm "just trying to help the guy out", too. While he is out spending money on a manual that won't lead him through a diagnosis, and spending money on unneeded parts, he will NEVER be able to save up for the necessary tools, like the FSM, to work on his car, effectively and economically.
RACE ON!!!
Old Jun 13, 2007 | 12:37 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Old Jun 13, 2007 | 01:03 PM
staugur's Avatar
staugur
Originally Posted by CFI-EFI
HUH???
RACE ON!!!
sorry not paying attention 90 and up are fixed!! must be the spelling.
Old Jun 13, 2007 | 03:07 PM
CFI-EFI's Avatar
CFI-EFI
I agree that trying to decode the spelling and grammar make reading some posts a challenge.
The TPS in the '90 and up IS non-adjustable, but changing to an adjustable TPS accomplishes nothing.
RACE ON!!!
Old Jun 14, 2007 | 03:05 AM
staugur's Avatar
staugur
RACE ON!!!
then why were the earlier ones adjustable?
Old Jun 14, 2007 | 07:02 PM
  #33
CFI-EFI's Avatar
CFI-EFI
Pretty much for the same reason the later TPSs aren't. 1989 and earlier ECMs are programmed to see ~.54 volts to indicate a closed throttle. Starting in 1990 the ECMs got smarter. They look at the TPS voltages and know to sort through the voltage readings and accept the lowest reading as closed throttle. Adjusting a 1990, up, TPS accomplishes nothing because the ECM will interpret the lowest reading as closed throttle.
RACE ON!!!
PS. I found that in my 1984 FSM. And also, NO C4 has a low oil pressure fuel cut off.
