87 sagging rear deck edge
Old Jun 14, 2007 | 02:40 PM
larrybee's Avatar
larrybee
Default 87 sagging rear deck edge
87 rear deck is sagging at bottom in middle between the exhaust, is there a fix or kit for this ?? - anyone. thanks.
Old Jun 14, 2007 | 03:03 PM
lightning30's Avatar
lightning30
I asked on yahoo questions let me wait for an answer and ill tell you.
Old Jun 14, 2007 | 03:32 PM
Da Mail Man's Avatar
Da Mail Man
...yes, there is. i will look for it a bit later but i believe that gm put out a "repair bulletin" on how to fix it...if i remember, it involved getting some aluminum (or similar) and some epoxy and affixing the
epoxy-coated piece up under the inside of the "lip and clamping the piece with vice grips or equivalent...that will re-form the sag into it's original shape..it is a common problem and simple fix....i have also heard of using flat stock and drilling holes and using screws/washers and doing the same proceedure..
Old Jun 14, 2007 | 06:52 PM
FlyboyZR1's Avatar
FlyboyZR1
This should help. I ordered the GM brace from www.vintageparts.org, and plan to attach it with JBWeld and a couple of clamps, should easily fix the problem.
http://forums.corvetteforum.com/show...1349527&page=2
Old Jun 14, 2007 | 07:09 PM
Da Mail Man
ouch!...he beat me to it!
THIS IS THE FIX FOR THE CENTER BOTTOM OF THE REAR BUMPER SAGGING DUE TO AGE OR HEAT.
Here's the fix: P/N 14069615 = $5.11
The problem and solution is described in the following bulletin:
Service Bulletin Number: 87-176
Bulletin Sequence Number: 142
Date of Bulletin: 8707
NHTSA Item Number: 93533
Make: CHEVROLET
Model: CORVETTE
Year: 1987
Component: STRUCTURE:BUMPER ASSEMBLY:ATTACHMENTS/SUPPORT BARS
Summary: REAR BUMPER FASCIA SAGS-CORRECTED BY ADDING A REINFORCEMENT-CENTER REINFORCEMENT , P/N 14069615, BETWEEN EXHAUST OUTLET NOTCHES IN FASCIA-POP RIVET REINFORCEMENT TO INSIDE SURFACE OF FASCIA USING FOUR (4) 2436998 RIVETS-ALL CHEVROLET 1987 CORVETTE MODELS
Works for all (1984-1990) flat-tail C4's
__________________
To 87 sagging rear deck edge
