what dose code mean
Old Jun 9, 2007 | 08:03 PM
cbarmy04's Avatar
cbarmy04
Default what dose code mean
my friend told me how to get the code with the check engine light. what dose it mean when it flashes 21.
Old Jun 9, 2007 | 08:46 PM
cbarmy04's Avatar
cbarmy04
oh my car is an 84 crossfire
Old Jun 9, 2007 | 09:01 PM
CFI-EFI's Avatar
CFI-EFI
It means that it is time to buy a FSM. Knowing what circuit caused the check engine light to come on doesn't tell you how to trouble shoot for the cause without throwing parts at it. Code 21 is TPS (high).
RACE ON!!!
Old Jun 9, 2007 | 09:13 PM
cbarmy04's Avatar
cbarmy04
thats some thing to do with the trotle. my car idles high but smooth after a few min it will drop to an un steady idle of 700-800 and some time 600.
Old Jun 9, 2007 | 11:02 PM
bldavis11's Avatar
bldavis11
It's the throttle position sensor. A Helm's manual is the best $100 you will spend on the car. It has diagnosis trees for just about every code in there.
Old Jun 9, 2007 | 11:04 PM
cbarmy04's Avatar
cbarmy04
cool but i cant a ford it right now do u have 1
Old Jun 9, 2007 | 11:45 PM
cbarmy04's Avatar
cbarmy04
if yal chould give me som ideals on what to look for and check befor i go reaplaceing stouph
Old Jun 9, 2007 | 11:53 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Is this a joke? I can barely figure out what you're trying to spell. Are you mashing the keyboard with your nose to type?
Old Jun 10, 2007 | 03:10 AM
bogus's Avatar
bogus
yea, well... product of a quality public education here in the good ole USA...
Old Jun 10, 2007 | 03:52 AM
staugur's Avatar
staugur
for ****s sake do you see the arrow with abc on your top toolbar?If you hit it we might have a clue as to what you are talking about!!
Old Jun 10, 2007 | 04:24 AM
bogus's Avatar
bogus
allow me to try translating this:
If you all could give me some ideas on what to look for, and check, before I go replacing stuff [that would be nice!].
Old Jun 10, 2007 | 10:24 AM
LouisvilleLT4
After searching his posts, these are pretty routine typing habits for him. I'll give him the benefit of the doubt and assume English is not his first language.
If it is your first language, cbarmy, come on man. Put a little more time and quality into your posts, we really do appreciate it when people do.
Old Jun 10, 2007 | 01:44 PM
cbarmy04's Avatar
cbarmy04
im dislexic and army what do ya'll expect
Old Jun 10, 2007 | 01:47 PM
cbarmy04's Avatar
cbarmy04
you are the only bobos that dont understand what im typing so whats that say abought u
Old Jun 10, 2007 | 02:36 PM
bogus's Avatar
bogus
yo, chill.
it's about the ability to communicate. Sorry to hear about the dyslexia. that sucks. but using the spell checker could help.
Old Jun 10, 2007 | 03:11 PM
cbarmy04's Avatar
cbarmy04
didn't know it was there thanks but do you know what code 22 is
Old Jun 12, 2007 | 01:43 AM
staugur's Avatar
staugur
throttle position sensor(TPS) circuit.signal voltage too low.i.e. less than .2 volts.
To what dose code mean
Old Jun 12, 2007 | 04:52 AM
imp65409's Avatar
imp65409
Hi, code 21 and code 22 are for the throttle position sensor (TPS). Sounds like your TPS is bad or not adjusted right. Since you may not have the money for the Helms manual I would suggest you get the Haynes corvette manual at Autozone. I think the manual is like $20. If your are going to change/adjust the TPS you will also need a set of torx bits, not sure what size it is, sorry. You will also need a digital vote meter(DVM). In the Haynes manual the procedure is in chapter 4 page 12 steps 74-79. It can be a pain to check this but its not that hard. The 84 TPS is different then the 85 and up.
If you cannot figure out how to do this try to get the help of a buddy.
I just did this on my 87 and found I had a bad TPS. As I write this Im waiting for napa to open so I can get a new TPS.
Hope you can get it fixed, good luck!! Dave
Old Jun 12, 2007 | 07:24 AM
runner140*'s Avatar
runner140*
That was shocking!
Old Jun 12, 2007 | 07:25 AM
runner140*'s Avatar
runner140*
Thanks.
