1989 computer chip
Old Jun 11, 2007 | 06:53 PM
kips vette's Avatar
kips vette
2nd Gear
Default 1989 computer chip
Hi will a 1991 computer chip work in a 1989 corvette
Old Jun 11, 2007 | 07:08 PM
pablocruise's Avatar
pablocruise
The 91 is a MAP car and the 89 is a MAF car.
*edit:
oops, sorry, I should have included the word "no" in there.
Old Jun 11, 2007 | 07:28 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
= NO
Old Jun 11, 2007 | 09:37 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Originally Posted by AGENT 86
= NO
1989 was the last year GM used the Mass Air Flow (MAF) sensor, which simply put, measured the amount of air the engine was taking in then used that information to determine how much fuel to deliver. In '90, they switched to the Manifold Absolute Pressure (MAP) sensor setup which used look-up tables to determine the amount of air the engine was taking in based on manifold pressure (among other inputs). Although both accomplished the same goal, the ECU programing between these two systems was considerably different.
If you're looking for a chip for your '89, check out the scan and tune section of the forum. You'll find more than enough information, and you can find individuals that will burn one for you.
To 1989 computer chip
