All with modded or new engines
Old Oct 25, 2001 | 07:43 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default All with modded or new engines
I know the stock L98 calls for 5W-30, but the everyone I've asked said thats not the right weight for a new engine. What weight shoud I go with and what kind? I was leaning towards Mobil 1 5W-30 but was told to wait on that. Also, what filter do you guys use?
Old Oct 25, 2001 | 08:12 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: All with modded or new engines (vettes rule)
I have always used 10W30 Mobil 1. in my stock L98 and my new motor
and only use AC Delco filters..
Old Oct 25, 2001 | 08:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I run 5-W30 full synthetic year round.
I have heard that it's better to use petrolium based oil for the brake in period; not sure what weight though. Maybe you could ask your engine builder or supplier or check with a cam mfg.
Old Oct 25, 2001 | 08:31 PM
Red85's Avatar
Red85
Default Re: All with modded or new engines (65Z01)
I agree with Jeff.....use Mobil 1 10-30 in your state of Tn. It gets cold there, granted, but not not below zero....right? That's what I'm running here in Texas.
Delco filters are fine. I've always been a Fram guy, but just get a quality one and not something the corner lube shop throws on.
Old Oct 25, 2001 | 08:56 PM
-=Jeff=-'s Avatar
-=Jeff=-
Yeah I heard that too.. for the first 1000 miles I used 10W30 Mobil DINO oil..
but then the factory fill for Vettes ids Synthetic..
[Modified by -=Jeff=-, 6:56 PM 10/25/2001]
Old Oct 25, 2001 | 09:06 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: All with modded or new engines (-=Jeff=-)
Ditto that... I always broke my motors in on regular oil, then switched to synthetic after 3K.
Old Oct 26, 2001 | 09:30 AM
your drinking buddy
Cruise-In V Veteran
Default Re: All with modded or new engines (Springer's 95)
How about 10W-40 Castrol till the next change, then Mobil 1 10W-30?
Old Oct 26, 2001 | 11:59 AM
h rocks's Avatar
h rocks
I am going to end up with a very similar setup. I intend on dino oil break in, then a shift to Mobil 1. Prolly a 50/50 blend of 20W50 and 5W30. I think the straight 5W30 Mobil1 allowed some wear over the past 10,000 track miles. I think a bit more viscosity will help the longevity in my situation.
Aside from the oil discussion, what all did you do to the components that you installed on the ZZ4 shortblock? Were there any gotchas in the change over of your parts/sensors etc to the ZZ4? Did you replace your clutch?
Old Oct 26, 2001 | 12:46 PM
your drinking buddy
Cruise-In V Veteran
Default Re: All with modded or new engines (h rocks)
h rocks, I didn't install or build my engine, had my uncle who owns a Corvette resto shop do it, but I can tell you that most of the parts should hook back up snice the ZZ4 is like the L98 design (I think). Sorry for not being able to help, im just a 16 year old :jester :chevy
Old Oct 26, 2001 | 01:14 PM
Aggravated4life's Avatar
Aggravated4life
Use 10W40 for the break in period.
Then use alighter weight and type of your choice.I always use delco filters.
As long as ya change the oil on time,the engine will be fine.
Old Oct 26, 2001 | 08:54 PM
corvette1990's Avatar
corvette1990
Default Re: All with modded or new engines (Bill's86Coupe)
I am using 10w-40 Penzoil DINO for breakin. Soon I am switchin to 10w-30 Mobil One syntech. My original 108 k motor was so clean on inside from a steady diet of Mobil One I couldn't beleive it. Never seen such a clean old motor.
As for my left over zz4 parts, they are still in garage and for sale in forum parts C3. Was an ideal swap, except for minor mods (grinding) to one bolt at 10:00 on the timing chain, switching to short water pump, Using old distributor, and swapping carb intake for a SuperRam. Stock intake, I was told would have to wallow/angle the center intake bolts.
Old Oct 26, 2001 | 09:07 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
I use 30 weight for the initial startup and then go to dino 10W-30 for the next 1000 miles. You can use synthetic if the cylinder walls are honed the same way they are at the factory. The dino oil is necessary to allow the rings to seat. I guess they don't seat as quickly with synthetics.
To All with modded or new engines
