24lb injectors?
Old Oct 26, 2001 | 04:28 PM
KYVette90's Avatar
KYVette90
Default 24lb injectors?
My buddy has a whole set of 24lb injectors off of a 92 LT1 that has been sitting for eight years without a single start. The injectors are all clogged. Is there any way to take them apart and clean them or to free them up? Will they work as a replacement for 19lb inj in my 90?
Old Oct 26, 2001 | 04:31 PM
GlockLT4's Avatar
GlockLT4
Default Re: 24lb injectors? (KYVette90)
About $50 and you can get them cleaned at a good shop i believe.
Old Oct 26, 2001 | 04:37 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Rich at Cruzin performance can clean and balance them for about $80.
http://www.cruzinperformance.com/
Old Oct 26, 2001 | 04:39 PM
pablocruise's Avatar
pablocruise
I've read good things about a guy named Rich at a place named Cruzin performance. He rebuilds or goes thu injectors.
Old Oct 26, 2001 | 08:00 PM
KYVette90's Avatar
KYVette90
Default Re: 24lb injectors? (89 Paul in cal)
Will 24lb inj's work in my 90 with the mods I have listed below? I beleive the original injectors are 19lb.
Old Oct 26, 2001 | 08:39 PM
pablocruise
The flux capacitor requires more lb.s per hour :crazy: :lol: . I didn't see if you have a bigger cam or bored out block.......any internal dimensions been changed? Head work? Bigger valves?
Old Oct 26, 2001 | 08:44 PM
corvette1990's Avatar
corvette1990
With the larger injectors, you will need to be able to adjust the fuel pressure. Your Chip should also be adjusted for pulse length, so I am told. The only way to really tell if you have the right parameters is to dyno with a wide band fuel/air oxygen sensor measurement. Too Lean and you burn holes in your piston, too rich and you bog down at wide open throttle.
Old Oct 26, 2001 | 09:12 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
You can use them in your 90 but you'll need a new chip to change the injector size parameter. The other downside is that your fuel mileage computer will no longer be accurate. It will be off by the change in injector size. I found that out on mine just recently.
Old Oct 26, 2001 | 09:16 PM
corvette1990
Default Re: 24lb injectors? (AquaMetallic94LT1)
Damn, that explains the difference in my fuel mileage computer. Thought it was goin screwy on me. Thanks!!!
To 24lb injectors?
