1986 Climate Control Panel Problem
Old Jun 12, 2007 | 06:47 PM
mattgreen298's Avatar
mattgreen298
Default 1986 Climate Control Panel Problem
Yesterday my climate control panel worked fine today it is not getting any power. I checked the fuse panel and all the plugs even the one on the back of the panel and all seems to be connected. Is there a relay I am missing or is it time to get a new one? (original part).
Old Jun 15, 2007 | 08:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Did you TEST both fuses that are in the main fuse block ??
http://members.shaw.ca/dankai/AC%20Electronic.pdf
Old Jun 15, 2007 | 02:07 PM
SunCr's Avatar
SunCr
Maybe ground not power. That runs to driver's side kick panel. Remove hush panel to access.
To 1986 Climate Control Panel Problem
