90 Power Loss (Help Please)
Old Jun 13, 2007 | 04:49 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default 90 Power Loss (Help Please)
Need to ask for some help.
Am from the C3 forum and over at my Brothers trying to help him track down a problem with his 90. His vette has been running well until it began to get sluggish. He took it to the shop and they are saying that cylinders 3 and 7 are not firing properly. Mechanic noted that the spark is fine, fuel pressure is good, no codes and he can hear the injectors working. But told my Brother to note that when he unhooks the injector wire...the idle doesn't change...so there is a problem with the injector.
This doesn't make sense...especially to me who is use to carbs.
Seriously... could really use some advice on what we can look at to try to narrow this down and fix. Day is almost over here in Milwaukee and we were going to take his 90 to Bloomington tomorrow for the weekend.
Thanks in advance... Ed
Old Jun 13, 2007 | 05:08 PM
geogolf's Avatar
geogolf
Default 90
could be any number of things from clogged cat to bad inj. as you said if you have a voltmeter you can ohm the injs. and they should read 15/17 ohms each more like 16/17 but if you have any that way off that the prob. maybe just a dirty fuel filter
Old Jun 13, 2007 | 06:34 PM
jghmczo6's Avatar
jghmczo6
Also look at the 02sensor.
Old Jun 13, 2007 | 09:50 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Try ohming the injectors on the cyliners that are not firing. '90 stock fuel injectors are Multitechs, which are known for going bad.
Ask me how I know.
Old Jun 14, 2007 | 12:37 PM
dhoughton's Avatar
dhoughton
Default sluggish
I had a similar problem just a month ago and barely made it home. My 90 was overheating, choking and more. The '90 cat was falling apart inside and the engine could not exhale. One easy check is to jack it up and wrap a small hammer in a small towel. Gently tap the cat and if you hear rattles inside then you cat is bad. Its a pretty easy job to replace. I have had two go bad on me. I replaced it with one hand, literly.
See you at Bloomington, Vette on.
90 vetter
Old Jun 14, 2007 | 02:41 PM
RacerX70CC's Avatar
RacerX70CC
Did you try a noid light on the injector plug (harness side) to verify injector pulse? If you have pulse at the connector, plug it back in on the suspect injector. If the engine doesn't smooth out, then you've eliminated the harness/ECM from the equation - leaving you to look at the injector. Use a mechanic's stethescope on the injector body and listen for actitivy. No clicking - dead injector.
Has the mechanic checked compression and/or leakdown on the suspect cylinders?
And something that can be really easy... are the #5 and #7 spark plug wires crossed? VERY easy for that to happen.
Cover the basics first before condemning the ECM.
Good luck!
Old Jun 15, 2007 | 08:44 AM
Sam Lam's Avatar
Sam Lam
Ask me how I know.
Here is some interesting info on your injectors. Rich Jensen (Cruzin Performance Injector service) is well respected on the forum and here are his comments on Multec Injectors:
Hi Bob,
The problem you currently have is that from 1989 through 1991 on the L98 engines GM installed Multec injectors. These injectors have one of the highest failure rates of any injector ever installed. It's not a matter of "if" they are going to fail, it's simply a matter of "when" they will fail. That is why some of your injectors look differently than the others. Some of them have obviously already failed and were replaced. Because of their design they cannot be repaired so the only solution is to replace them.
You can try to find some of the same injectors to use as replacements however they will likely eventually fail also so a better alternative is to replace them with an aftermarket set of replacement injectors or find some of the earlier Rochester injectors that were used from 1986 though 1988 on the L98's. These were a Bosch design injector and they don't have the problems that the Multecs do.
Sorry to be the bearer of bad news but that's just the way the Multec injectors are.
Hope this helps. Let me know if you need more info or have additional questions.
Rich Jensen
Here is a GM Service Bulletin on the same issue:
The good news:
1. Easy to check for problem.....you can do yourself!
2. Relatively easy to replace injectors.....you can do yourself! However, do not buy GM repalcements as you net worth will be reduced.
3. Cost will be about $325 for new injectors and gaskets.
Let me know if you need more info on this. BTW, the resistance spec is 16.5 +/-.3 ohms and all eight injector resistance should be close to the same value.
Suggest you review this thread on the same topic:
http://forums.corvetteforum.com/show....php?t=1727763
Let us know what you find on this
To 90 Power Loss (Help Please)
