Strange opti spark problem
I remove the old opti, connect it up hold it in my hands and spin the wheel, same thing, coil fires, fuel pump runs, got good signals at the TECH2, put the damn thing back in the engine, remove the cap so I can see if the rotor turns and it does upon engine crank but still no signals. OK WTF! Plug in a brand new MSD into the engine crank her over and SAME DAMN ISSUE! Now its WTF *&^!@*@&#@!!
So I remove the PCM plugs check all power and grounds and continuity of the opti signal and power wires to the PCM plugs, all grounds check out to <.5 ohms to the battery cable, power is fine at all points, there are NO DTCs in the PCM.
So anytime the opti is installed there are no signals from the opti during crank and no start, the thing spins with the engine so its not anything mechanical binding it up, take the POS out of the engine spin it by hand and its fine, anyone come across something similar? I gotta spare PCM at home that I will try tomorrow.......
I screwed the MSD timing screw all the way in and it fired right up.....
I dont know if youve tried that or not....worth a shot anyway...
... at least I still had spark..
I didnt/dont have a tech2 to check for signal.
Good luck
