which low temp fan switch to get
with CFI on this, there have been way to many arguments over it. Companies have spent thousands of dollars testing and publishing their results just to have some backyard mechanic refute or suggest the test may not have truley been done...to that I say You guys can run what you like....but I think the general had a pretty good handle on it and he never installed a 160 thermostat. Not in the 265,283,305,327 or 350.
and dont repost that silly wear vs. temp chart, that came from God only knows where, and when, and by who, under what conditions....
if i see that thing posted again, as somebody`s "proof", i`m gonna puke...
i have a suspicion that the people who originally did that test, if it ever actually occured, probably died of old age, over 30 years ago....
i have owned several cars that have racked up well over 100,000 miles with 160 stats, (a couple WAY over 100K) with compression thats still good, only to tear them down later for modifications, or repairs that are clearly not related to cool operating temps, only to find cyl. bores,pistons, rings, ect., still in exellent condition....
how about you???
how many engines have you operated at 160 for many years, and many miles have personally inpected. hmm???
NOW! Why do you bust into a thread with not ONE word on subject??? Thank you for the spelling lesson. NOT!!!
RACE ON!!!
PEACE
lets see, who did that test again? when? what were the test conditions??? what engines were used????
say, if i were anonomously post a graph that inverted that one, and showed more wear from higher temps, what would you think then?
or would you be in too much turmoil over which to believe, to take sides?
according to that chart, every engine out there with 100K of daily driving, with a couple of cold starts a day, should be so badly worn out that its incapable of running...
surely the engines i`ve torn into that i KNOW were operated cool long term should have bored themselves .100"+ oversize....
but they werent....
gosh, all those dirt track engines (coundnt begin to couny how many)
i helped tear down and rebuild, some that had several
long hard seasons of racing on them, most of which never had a thermostat, that had surprisingly good good condition bores...
i used to believe those graphs too, until first hand experience showed me that the wear rates in those graphs, werent anywhere near accurate....
but, hey. what the hell do i know, right? i`m just some "backyard" type of guy, that has personally seen lots of engines that have somehow defied the "laws" of your mystery internet charts say cant possibly exist...
like i said, when you have PERSONAL EXPERIENCE with cool operated engines, instead of what others tell you, with charts from who knos where, come back and talk then...
maybe cool engines do wear cylinders/pistons/rings at a slightly faster rate than warm engines... but it damn sure doesnt occur at the rates shown in that graph shown on here... i`d say the difference is quite small...
common sense should tell anyone that... but why use common sense, or think for yourself, when you have a graph from somewhere on the internet???
but many other components tend to last longer at lower temps. headgaskets, valvestem seals, external engine plastic parts, such as wiring, wire loom, electrical connectors, various other gaskets, O-rings, ect., ect....
until then....
RACE ON!!!
PEACE
And now that you have hijacked the thread:
RACE ON!!!
couple that with CFIs suggested reading and search these archives.
I know I'm old bigLee (63), so forgive me if I can't recount all the engines I've built for the strip or just because they were due! But I'm still learning.
I don't mind. Did I act as if I took offense? I do admit to being somewhat intolerant of illiteracy, but I don't jump on every misspelled word or typo that pops up. Also, if I do comment, it is in addition to the subject at hand, and not an attack out of the clear blue. You had no thoughts on this subject before or since your off the subject post.
And now that you have hijacked the thread:You should take some of your own "ADVISE" Pot calling the kettle, black??? Glass houses, etc.
RACE ON!!!
P.S. It seems to me according to the experts; An engine that is constantly running in the range of 175 to 180 dgrees will have optimal engine longevity. Am I being taught and expected to believe that if I run a 160 thermostat my engine will run cooler than 175 degrees? Some of you think you are running some kind of automotive school here but that is not true. Look up the definition of forum.
RACE ON!!!
Since I just can't resist putting my 2 cents in, and since I have temp on the brain today...
180 is considered optimum.
160 is too cold.
Anyone have any idea how to get my LT1 anything close to those temps with the a/c on?
It really doesn't make much difference. Keep it between 160 and 220. Even if your Vette hits 230 on occasion it shouldn't cause trouble. That's normal. Your engine temps will change depending on different driving conditions and outside temp. Your engine will not crumble if your temps are not within the so called optimim range.
If any of you think you know better than the engineers who designed it, the burden of proof is squarely on your shoulders, not the other way around, not on those using the factory stuff.
So if you think GM is wrong about the operating temps, PROVE IT. If you think they run higher operating temps for emissions at the sake of performance or longevity, PROVE IT.
I'm not implying that the GM engineers are all-knowing. They have apparently screwed up plenty of designs. But if you think you know better and want to tell everyone about it...
...PROVE IT.
"Tests have proven that by simply opening the thermostat precisely at the same temperature over and over again, the engine remains cooler on the average." " This results in longer engine wear and consequently longer engine life"
You got this right! " That "magic" number is 175-180 degree range, which requires a 180 degree thermostat."
"The all to commonly used 160 degree thermostat is way too low to be considered for performance or engine longevity."
I just don't understand why the personal attacks on people who provide statistical data, graphs and additional resources for inquisitive minds by some who believe their limited experience proves the multitude and professionals wrong?
Here's some more pertinent info, not an answer though... courtesy of the people that think for a living so you don't have to (engineers).
http://www.eng-tips.com/viewthread.c...=176339&page=7
(and yes, that damn temp/wear graph got posted also
