supercharging info
Old Jun 17, 2007 | 01:40 AM
zmanz1's Avatar
zmanz1
Default supercharging info
hi all, i have a ce vert with 14000 bone stock miles, do i need to do any mods to add a supercharger which one do most guys run?
Old Jun 18, 2007 | 04:11 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I hope you get an answer, I have the same questions.
Old Jun 19, 2007 | 01:00 AM
Mo_Bandy's Avatar
Mo_Bandy
It pretty much depends on how much power you want to run...
If you want to run the stock bottom end, you can run 6~8 pounds of boost with an FMU or a boost a pump. Many folks are doing that...
You may want to consider water methanol injection, larger injectors i.e. 36-42 poundrers. Again depends how far and serious you want to get...
If you have more specific queestions please feel free to email or PM me...
Regards,
MO
Old Jun 19, 2007 | 01:02 AM
BAM92's Avatar
BAM92
Go to www.blowerworks.net. If you are looking for a great all around kit and don't want to do much if any fabrication, this is the place to go. Down to every nut and bolt.
Old Jun 28, 2007 | 12:05 AM
wayne lowry's Avatar
wayne lowry
For the cost of the supercharger you could do a nice heads and cam package with tuning and the supporting mods to go along with it.
If your car is stock and and an auto you could go with gears and a converter and pick up nearly a full second in the 1/4
To supercharging info
