Master Cylinder
Old Jun 17, 2007 | 10:15 AM
Livin the Dream's Avatar
Livin the Dream
Default Master Cylinder
My master cylinder is leaking on my 88! It appears to be leaking out the booster vent ? Anyone ever had the seal at the back of the cylinder go out? AM hoping it is a cylinder only problem and not something with the booster. Thanks Kevin
Old Jun 17, 2007 | 10:57 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
They almost always leak out the back. Get a new master and bench bleed it. put it on and then bleed, flush out your brakes. you should be fine. If your booster was leaking you would have a vacuum leak.
Old Jun 17, 2007 | 06:03 PM
Livin the Dream
Default Thanks
That was my plan but was worried the fluid could/may have damaged booster Thanks Kevin
Old Jun 17, 2007 | 06:09 PM
jimmers's Avatar
jimmers
There is a change it might have. I replaced my master cylinder last year because fluid was leaking into the booster. A few months later my booster went south. When I removed the booster from the car some fluid came out.
Old Jun 26, 2007 | 09:58 PM
Livin the Dream
Default Follow up! Brakes are GOOD
After much research I did several things
1) bought helms manual
2) bought speed bleeders
3) used the partsladi on ebay
Followed the manual on the bleed procedure afteer bench bleeding!
No problems less than 2 hours start to finish! Now I can get down to enjoying the car I hope! Is new to me and I have driven it 2 times
Thanks for the input! What a great forum!
Old Jun 27, 2007 | 09:43 AM
Aardwolf's Avatar
Aardwolf
Great! Remember to wave!
To Master Cylinder
