Just got another vette!!
Old Jun 18, 2007 | 05:01 PM
93 ragtop's Avatar
93 ragtop
Default Just got another vette!!
Hey, I know this is the tech section, but here is where most of my buddies hang out. So to make it a tech question, what do you think my new car will run in the qtr? Below is a list of the basic mods done to it by forum member " Bruce"
It is running 335x35x17 tires, 3.45 gears and a 6 speed. Oh, and one other question, do you think traction will be a problem?
Sorry that Im bragging, Im just so happy to have this car!!
I used "copy and paste" to list the mods he has done below
Agostino Racing Engine built
383ci LT1 .030 over bored
Eagle 4340 3.75 stroker crank
Eagle 4340 6.0 H beam rods
JE -28cc heavy duty piston
JE Rings
ARE ported&polished stock heads with 3 angle valve job
1.56 x 2.02 manley severe duty valves
10* titainium retainers
Comp double valve springs
1.6RR Crane gold roller rockers
Custom cam 222/230 @.05 .565/605 LSA 114
Trick flow .08 wall thickness chromoly one piece push rod
Clevitt 77 H series bearings thru out
Comestic head gaskets
ARP head studs
High volume melling oil pump
6Qt Morroso oil pan
Cloyes double roller timing chain
Mezire electric water pump
58mm BBK TB
Delteq Ignition system
95 Opti used for crank reference only
Upgraded 95 intake manifold powder coated red
Upgraded 95 fuel rail with welded on -10AN fittings at each end
DFI Gen 7+ ECU
2 bar map sensor
50s injectors
Twin 255 GSS340 intank fuel pump
-10AN stainless braided feed line
-06AN stainless braided return line
Large Aeromotive external fuel pressure regulator
M'cloud street twin clutch
17x9.5 ZR1 5 spoke wheel front
17x11 ZX1 5 spoke wheel rear
Twin pod boost/fuel pressure guages
Custom rear mounted turbocharged
TV85mm T6 garrett turbo (capable to flow enough air for 1200hp)
Turbonetic 42mm race gate
Tial 50mm BOV
Shureflow self prime heavy duty oil pump(return turbo oil)
Water to air intercooler
Custom 5 gallon water tank chilled by ac system
Custom 5" exhaust V band
304SS 16g 3" diameter piping and Swain tech coated hot side
Cold side 3" diameter piping aluminize
Turbo housing Swain tech coated
Catless
Custom 6 points roll bar with door swing out.
By the way, Ill bet there are not too many other members who own 2 white 93 conv. vettes.
Old Jun 18, 2007 | 07:19 PM
hgh pwr's Avatar
hgh pwr
easy 10 sec,congrads I would have liked to buy that car myself.
Old Jun 18, 2007 | 07:29 PM
jslt1's Avatar
jslt1
10's if you could get it to launch, like putting on slicks/skinnies no, telling maybe a high 9sec. surprise..??? Only one way to find out though
Old Jun 18, 2007 | 07:31 PM
creoleman's Avatar
creoleman
Congrats! Sounds like a really Boss Ride!
Old Jun 18, 2007 | 07:32 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Congrats Rich!!
That thing is bad ****.
Now go back in your room and don't you come out until you have pictures.
Old Jun 20, 2007 | 05:51 AM
93 ragtop's Avatar
93 ragtop
Ill try to take a few pictures this weekend and then figure out how to post them. Never done that before. But thanks to everyone for the comments.
Old Jun 20, 2007 | 07:33 AM
runner140*'s Avatar
runner140*
And the fun begins....Lets see some pics.
Old Jun 20, 2007 | 07:43 AM
hookedup's Avatar
hookedup
Hey Richard!
Congrats on the new ride
Better start looking for that stacker trailer so you & your wife can race
Dave
Old Jun 20, 2007 | 08:12 AM
mn_vette's Avatar
mn_vette
That wouldn't happen to be Bruce's car would it?
Its a bad **** car, I'm sorry that he lost interest in it, but you got one HECK of a deal because of it.
Be sure you treat it right, full throttle every chance you get
And don't be afraid to come hang out in the C4 FI/Nitrous section if you need any help or just to let us know how its going.
Old Jun 20, 2007 | 08:36 AM
BlackC6LS3's Avatar
BlackC6LS3
Sweet! Congrats so what are the plans for your other car now?
Old Jun 20, 2007 | 03:47 PM
93 ragtop's Avatar
93 ragtop
Originally Posted by hookedup
Hey Richard!
Dave
Hey Dave,
Sounds like a good idea to me, just not sure she will go along with it.
By the way, I have a few drag racing questions I wanted to run by you. I will send them by pm soon. I really value your opinion!!
Old Jun 20, 2007 | 03:52 PM
93 ragtop's Avatar
93 ragtop
Brian, yes, this is Bruce's car. It has set for awhile and has a few bugs to work out. The oil pump for the turbo is leaking real bad and there is no power going to it. And the DFI has the base program for a 377 twin turbo tune for now. It starts and runs but needs tuned. With that, I am going to need help or take it to someone after fixing a few leaks etc.
I will really appreciate your help and others in the forced induction section in the future!!
Old Jun 20, 2007 | 03:54 PM
93 ragtop's Avatar
93 ragtop
Im going to keep it for now the way it is. Funny thing is, I just purchased a short block from Golen engines for it, and had purchased a supercharger kit last year, which is setting in the garage.
Old Jun 20, 2007 | 04:07 PM
snowmaker2000's Avatar
snowmaker2000
Well, if you run out of room, I have space in my vette....ah hem!. . . I mean . . . .in my garage for those items. I won't even charge ya. Hows that for being a sport.
Old Jun 20, 2007 | 04:28 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
WOW !!!!!!!!!!! CONGRATS
That sound like some ride
Old Jun 20, 2007 | 05:08 PM
STL94LT1's Avatar
STL94LT1
You got a steal on that car. I know Bruce put alot of money , time, and love into the build.
Looking forward to seeing some track times.
-Mike
Old Jun 20, 2007 | 11:56 PM
BlackC6LS3's Avatar
BlackC6LS3
I knew about what you had planned but figured something would have changed since you got the new car. Goodluck with both of them and get us some pics! Shoot me a PM if you need someone to host them and post them.
To Just got another vette!!
Old Jun 21, 2007 | 08:57 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Nice list of mods
Old Jun 22, 2007 | 06:11 AM
93 ragtop's Avatar
93 ragtop
: Shoot me a PM if you need someone to host them and post them.
David, I appreciate the offer and I may take you up on it!! Ill try to get some pictures this weekend.
Old Jun 22, 2007 | 08:03 AM
mseven's Avatar
mseven
Oh, and one other question, do you think traction will be a problem? Sorry that Im bragging, Im just so happy to have this car!!
no brag, you have every right to be happy Congrats ! the parts list is impressive, that will make a real fun ride. Traction?? lol...might be better for now to have some wheel spin
