Cam Question
Old Oct 26, 2001 | 09:12 PM
C4 Suke's Avatar
C4 Suke
Default Cam Question
Which is better, the hotcam, or a cam with
dur. - 270/276
dur. @ .50 - 218/224
lift - 495/502
Centerline - 114
I am looking for a cam that won't really give it a rough idle, I want it to run smooth.
Old Oct 26, 2001 | 09:46 PM
ChrisB's Avatar
ChrisB
Default Re: Cam Question (C4 Suke)
In a 350" motor the hotcom will still definitely have some lope to it. The cam you mention should be relatively tame - or about as large as you can go while having a near stock idle. It will be down on hp from the hotcam though.
Old Oct 26, 2001 | 10:09 PM
Red85's Avatar
Red85
Default Re: Cam Question (ChrisB)
The 114 degree overlap with that cam is high. You're looking at a higher stall TC (with an added cooler) to run it on the street, and even then with greatly reduced idle vacuum.
Old Oct 26, 2001 | 11:26 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: Cam Question (Red85)
What about the idle/performance for this comp cam, compared to the GM "HOT" Cam? Ive heard its a really nice grind.
Part Number 07-305-8
Engine 1993-1996 Chevrolet
350ci,
LT1 & LT4,
8cyl.
Grind Number LT1 276HR-14
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.51 0.51
Duration At 0.006 Tappet Lift 276 290
Valve Timing At 0.006
Open Close
Intake 28 68
Exhaust 83 27
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 220 230
Lobe Lift 0.34 0.34
Lobe Separation 114
Recommended Valve Springs 986-16
Old Oct 27, 2001 | 03:41 AM
ChrisB's Avatar
ChrisB
114 is the Lobe Separation Angle (LSA) not degrees of overlap. A wider (higher numerically) overlap will provide a *better* idle (than a narrower lsa).
The cam you mentioned is commonly referred to as the CC305, and has similar characteristics to the Hot Cam - with slightly more top end and slightly less mid-range.
Chris
Old Oct 28, 2001 | 11:07 PM
C4 Suke's Avatar
C4 Suke
How much hp loss would I see if I don't get the Hot Cam. I was looking to do it with heads but I only have money for the cam and roller rockers. The car will be a daily driver, and a lot of highway driving at high speeds and city driving too. Would a hot cam affect the drivability and reliablility? Thanks, Suke.
Old Oct 29, 2001 | 11:10 AM
Chris@SD's Avatar
Chris@SD
What cam are you looking for? Give me a ring on the rollers and the cam and such. We can help you pick your cam and match it to what you are looking for.
Thanks,
To Cam Question
