Melling Oil Pump Cracks
Old Jun 19, 2007 | 03:44 PM
billybonesmusic's Avatar
billybonesmusic
Default Melling Oil Pump Cracks
there was a thread here the other day about cracked M55HV pumps, here is the new one i got today, it even comes with a note saying "the pump has a new look due to a new housing & cover design, the changes inprove the pump on origional stock applications". but it also says...."any high performance application especially those using solid motor mounts require the installation of an M select performance oil pump".....ok......what is that? and why did this one cost $85??
but you can see by the pics..this one IS better though.
here is the pic http://www.billybonesmusic.com/billsvettepage.htm
__________________
Old Jun 19, 2007 | 04:54 PM
85vet's Avatar
85vet
Cruise-In V Veteran
The Select pump cost about $85. If you paid that for a standard, you got ripped off!!!!! Do yourself a favor & buy the select pump. It would be like buying insurance & peace of mind.
Old Jun 19, 2007 | 05:53 PM
billybonesmusic
this was the pump/pick-up assy welded on with hardened pumpshaft kit from summit, so thats why its more, this pump is solid though. its been changed,
Old Jun 19, 2007 | 06:08 PM
85vet's Avatar
85vet
Cruise-In V Veteran
But the included warning should give you a clue to what may happen. Hopefully nothing, but if you have a high performance engine, is it worth the chance?
Old Jun 19, 2007 | 06:13 PM
hgh pwr's Avatar
hgh pwr
the housing will crack on that pump hense the warning,i read an article in last months hotrod about this,you dont want that pump on a high perf. engine like 85 vet said do yourself a favor and return it to summit.I just bought the select pump and it was 62 dollars with out the pickup.
Old Jun 19, 2007 | 06:26 PM
billybonesmusic
what is the part number on that select pump?
Old Jun 19, 2007 | 06:40 PM
CFI-EFI's Avatar
CFI-EFI
Because of this question, I typed a guess at an address (URL) into the address bar of my browser. I didn't explore beyond the opening page, but I'll bet that everything you ever wanted to know about Melling, can be found HERE.
RACE ON!!!
Old Jun 19, 2007 | 07:09 PM
_twisted_'s Avatar
_twisted_
Default here is the original tip
This is the guy the wrote into the magazine, it was a long time ago -look how long it took to make it to actual print
Ed Hess melling thread at GoDragracing.com
Old Jun 19, 2007 | 08:23 PM
hgh pwr's Avatar
hgh pwr
10552 for the high volume pump from jegs.
Old Jun 19, 2007 | 09:20 PM
jeffyc's Avatar
jeffyc
to make a long storey short. i ended up puting in the 10555 in my 383
Old Jun 25, 2007 | 07:01 PM
Eike's Avatar
Eike
I dont't know exactly which pump I have. I think it is a 10550.
Would this pump be OK for a high perf. engine with big hp/tq and a 6000 rpm readline?
It looks like the right one in the picture, btw.
Old Jun 25, 2007 | 09:09 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I went with the std volume 10553.
However, look for that thread "melling oil pump disasters" it has several pages of good info. Including several pics. IIRC, you may actually have an older style good pump. At first glance, your mount area looks pretty beefy and does not have the sleeve of the newer weak style.
To Melling Oil Pump Cracks
