Moved to a vette
Old Jun 20, 2007 | 11:23 AM
Dub2Vette's Avatar
Dub2Vette
Cruising
Default Moved to a vette
OK guys I know how to use the search botton and found alot of atricles on the crossfire injection. But i wanted ot be able to get it up there to around 300hp. I saw people said throttle bodies, headers, exhuast, and intake mani. The question is where could I get most o f these items how much would they be and what would actully get my car up to par? I know i dont want to get a carb and heard that the xram isnt worth it, but maybe someone could really show me the way. Im not looking for a speed demon just want my corvette fast than my GLI. I love the vette because it RHD but seems like the engine i have is a bit out of style. Im sorry I had to bring this subject up on this again but seems like I needed a more direct way to figure out how to get this thing working.
Thanks and this forums looks well organized then others.
Old Jun 20, 2007 | 01:23 PM
derekguzz's Avatar
derekguzz
fill out ur profile and ull get alot more help...no one knows what year ur car is or anything about it
Old Jun 20, 2007 | 02:27 PM
JimMel's Avatar
JimMel
Wouldn't a CFI C4 be an 84?
s'pose it could be an 82, but then he'd be in the wrong place....
Old Jun 20, 2007 | 03:14 PM
Dub2Vette's Avatar
Dub2Vette
Cruising
Sorry I will work on my profile its and 84 auto.
Old Jun 20, 2007 | 03:35 PM
snowmaker2000's Avatar
snowmaker2000
Default Welcome to the Forum
There are all types of folks here willing and able to help ya out. Good luck with your new baby. You'll be hooked in no time. :-).
Old Jun 20, 2007 | 06:11 PM
Dub2Vette's Avatar
Dub2Vette
Cruising
Im already a car addict. I love my vdub but its time for a RHD car and the vette is my favorite domestic. Im really looking for someone to steer me the way to get this thing GOING!!!
Old Jun 20, 2007 | 06:20 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Get a dremmel, port your intake manifold. That right there is your biggest problem. It will free up a lot of power. Then swap your fuel pump for the '85 style. That way you have the fuel at WOT. The '84 pump is about 13psi and the '85 is around 30psi. I think. It won't make a difference at low throttle because of the pressure regulator. But it helps when you are punching it. Port your head's, and put on a better exhaust. And some 1.6:1 full roller rockers, and you should be doing fine on power If you can afford it, put on some better heads.
Old Jun 20, 2007 | 07:45 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Watch for posts from CFI-EFI on the cross-fire. His runs in the 13s with virtually nothing except intake mods.
(Approach with caution.)
Old Jun 20, 2007 | 07:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
you dont say....
Old Jun 20, 2007 | 08:21 PM
CFI-EFI's Avatar
CFI-EFI
What is par? I have cut over 2 seconds off of my 1/4 mile time for under $1300.00. The list of modifications I haven't made is as long as your arm. Start by porting your intake manifold. The X-Ram is the only commercially available intake for the Crossfire that I know of, and I'm not impressed. Anything else would be a conversion away from the Crossfire, which isn't necessarily a bad idea. Whatever you do, don't waste the time and money to convert to a TPI.
The Corvette is only domestic in the US and US destined cars are not RHD.
RACE ON!!!
Old Jun 20, 2007 | 08:28 PM
CFI-EFI's Avatar
CFI-EFI
Hogwash! Another old wives tale. TEST your fuel pump. If it puts out the regulated pressure at the times of highest demand, WOT, heavy load and high rpms, it is dong it's job. If the pressure doesn't drop, the engine is getting all the fuel it can use (more, really). Once the engine is getting all the fuel it can use, providing more is a waste.
RACE ON!!!
Old Jun 20, 2007 | 09:06 PM
Grease Monkey
RACE ON!!!
I know that it CAN provied enough... but isn't there less strain on the pump if you switch to a higher flowing pump? The pressure regulator will keep it at the optimal amount, but the pump will be working less. I am not saying that you are wrong, I know that you know a lot more then me on the subject. I am just saying what I have heard multiple people said to me.
Also I will be porting my intake soon, do you happen to have any pic's of your's so I can see how much to take off?
Old Jun 20, 2007 | 10:48 PM
Dub2Vette's Avatar
Dub2Vette
Cruising
Banned for life Im in va beach do you know where I could get my intake mani ported and how much it would be. Where could I get most of these parts. It seems like most of the parts just have to be ported/ bored out if im right? I already am getting a new exhuast so seems like im on my way. Can I pick up a used fuel pump or should I just get a brand new one.
Thanks for all your help.
Old Jun 21, 2007 | 10:08 AM
Dub2Vette's Avatar
Dub2Vette
Cruising
Should I get my throttle bodies bored out also?
Old Jun 21, 2007 | 11:14 AM
CFI-EFI's Avatar
CFI-EFI
On the subject of performance, if the stock pump "CAN provied enough" (sic) what is the point of spending money to replace a pump for one that won't, can't increase performance?
Probably. But what is the point? A later pump may last longer because it is being called upon to live an easier existence than it was designed for. Therefore when you NEED a pump an '85 is a good idea. But since it can't improve performance, what is the logic in going out to buy a pump that will extend the time before you will have go out to buy a pump???
There is a lot of that going around. Before you buy into the rumor of the day, THINK about what is supposed to be accomplished and how. The regulator determines the fuel pressure. If the pump can keep the regulator supplied where the fuel pressure doesn't drop off, no other pump can possibly do any better.
Sorry. I didn't take pics. Chances are, you won't remove too much. Most people don't remove enough. Thin is in!
RACE ON!!!
Old Jun 21, 2007 | 11:25 AM
CFI-EFI's Avatar
CFI-EFI
You can do it yourself.
Get most of what parts?
Don't buy a fuel pump until yours has failed the test.
I had my TBs bored after I tested the results of my manifold porting. It gave NO additional gain in 1/4 performance.
RACE ON!!!
Old Jun 21, 2007 | 02:29 PM
Demonic85's Avatar
Demonic85
When you take your intake off to port it out, you might want to consider a better set of cylinder heads. Aluminum heads are always a good option and you can find good ones just by searching this forum. You can use just about any heads designed for SBC up to '86.
To Moved to a vette
Old Jun 21, 2007 | 02:39 PM
Rohn's Avatar
Rohn
Default i moved to a vette too. a few years ago.
this is what i have done to date:
previous crossfire vette. 350 cid
3/2003 xram, 2.0 TB's, 454 injectors, edel rpm aluminum 64 cc heads, crame 2040 cam 210/216 @.05, crane roller rockers, ceramic hedman 1 5/8 headers, dual exhaust/crossover, hooker aero chambers, 7747. Innovative WB.
CHANGES COMPLETED 10/13/2004:
7.4L TB on Holley TBI manifold(Projection), Summit AC with K & N, Aeromotive FP reg, Comp Cams 224/230 @.05 114 LSA, Innovative input of tps/rpm/map data.
09/2005 fresh paint(red of course)
08/16/2006 added Prominator- 8746 ECU with EBL, IAT sensor being added following week.
05/2007 wired the WB controler to hide in glovebx with a digital A/F analog output gauge(blue) on pillar
06/2007 replaced stock wheels with chrome AFS ZR1 17x11 and 17 x 9.5
Old Jun 21, 2007 | 08:55 PM
Dub2Vette's Avatar
Dub2Vette
Cruising
How would I be able to do it myself?
Old Jun 22, 2007 | 11:59 AM
CFI-EFI's Avatar
CFI-EFI
What does that mean? How would you NOT be able to do it yourself?
RACE ON!!!
