Electrical problem
Old Jun 22, 2007 | 04:35 AM
racerseks's Avatar
racerseks
Default Electrical problem
I have a problem I can't figure out. Here's what's going on. All exterior lighting on the front passenger side has dimmer illumination than the driver's side. Turn signal seems a bit slow on that side as well, but does work. Now when I turn the headlights on, neither turn indicator will flash, and the park light on the passenger side does not light up. In addition, the third brake light does not work with headlights on or off.
Here's what I've done:
Replaced headlight, replaced turn signal bulb, replaced third brake light bulbs, replaced related fuses.
Can't figure this one out. Does anyone have any tips?
Thanks!
Old Jun 22, 2007 | 08:14 AM
pcolt94's Avatar
pcolt94
I would first start looking for a poor ground connection. The Helms FSM would be a great help here because it shows you the ground configurations and where they are.
The same go for the power distribution wiring. You can see if there is a relationship between the problem areas getting their power.
Old Jun 22, 2007 | 08:52 AM
shop14's Avatar
shop14
definately check for a grounding issue.
Old Jun 22, 2007 | 03:33 PM
racerseks's Avatar
racerseks
Thanks for the input What's the "Helms FSM", and where might I find it?
Old Jun 22, 2007 | 03:56 PM
jdeatsch's Avatar
jdeatsch
Default Helms
is located at www.helminc.com
They are a source for factory service manuals for our cars and many others.
That which you describe is, as stated above, most likely a ground issue. Too many things with too many issues to almost not be.
Start hunting is about the way to approach it.
hth,
Jim
Old Jun 22, 2007 | 10:07 PM
racerseks's Avatar
racerseks
Thanks.....I went and took a peak earlier today, and found a loose groundwire. Apparently the AC compressor kept popping fuses, and it was disconnected at some point, and I'm guessing at this time that this groundwire was taken off at the time. The signal and dimness problem seems to have gone away.
Right now, I just want it to pass a safety inspection.....so that means the lights etc. The third brake light is still not lighting up, though the bulbs have been changed. LOOKS good, in there.....any suggestions where to look for problems?
Thanks for the tips!
Old Jun 22, 2007 | 10:08 PM
racerseks's Avatar
racerseks
Right now, I just want it to pass a safety inspection.....so that means the lights etc. The third brake light is still not lighting up, though the bulb has been changed. Socket LOOKS good, and has not been changed yet.....but any suggestions where to look for problems?
Old Jun 23, 2007 | 12:50 AM
jfb's Avatar
jfb
The brake actuated switch has two contacts, one supplies power to the lower brake lights and the other supplies power to the high brake light. The blue wire on the brake switch goes to the high brake light and you can check for 12v on this wire, brake applied. The brown wire on the brake switch supplies power to both contacts.
To Electrical problem
