CCM problems on a 93
Old Jun 23, 2007 | 05:35 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default CCM problems on a 93
I am getting CCM codes 31, 33, 35, 37 on my car, the fsm says I have open circuits. Anybody shine some light on these codes for me? The fsm does not tell you much about these.
TIA
Old Jun 23, 2007 | 07:15 PM
bogus's Avatar
bogus
it should...
since the 92 and 93 are about identical, I have hit the ol' book.
check in book one, starting on (or about) page 8D-38.
It looks like there is a problem with the LCD, CCM or the wiring between the two.
Old Jun 24, 2007 | 05:28 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks, now tell me what the HECK is a DVM and what is the adapter from J35616???????????????????
Thanks,
Lost mind in FL
Old Jun 25, 2007 | 11:16 AM
barry96's Avatar
barry96
Also interested (96, 52K).
Immediate need is - will this affect an inspection as mine ran out a couple months ago!
Old Jun 25, 2007 | 11:28 AM
kalister1's Avatar
kalister1
DVM = Digital Volt Meter.
The FSM calls for Kent Moore tools to trouble shoot everything. Kent Moore J39700 Brake Out box is used to troubleshoot most systems, then you need the adapter to connect the box to the cars connector. Look for this stuff on E-Bay, the J39700 box can go between $20.00 & $100.00. Adapters show up once in a while. You may just get lucky and be able to read the pins right from the connector?
Old Jun 25, 2007 | 01:37 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Is there anything on these cars that can be easily diagnosed????
Thanks Kalister1
BTW, where is pasadena, I used to live in rockville?
Old Jun 25, 2007 | 02:18 PM
kalister1's Avatar
kalister1
Pasadena is between Baltimore and Annapolis.
Old Jun 25, 2007 | 02:32 PM
pcolt94's Avatar
pcolt94
Aside from the codes what kind of problems are you having with the car? What is not working?
Old Jun 26, 2007 | 08:46 AM
barry96's Avatar
barry96
In my case, the car seems to be running normally (with some unknown whistling noise when I give it some gas that I haven't tracked down yet). I did notice the SYS flash a few times but I thought that was a weak battery. I just bought a battery tender but I haven't hooked it up yet.
Manual says that these codes should clear by themselves at next start up of the CCM but that didn't happen. They did stay clear so far after I cleared it manually.
Old Jun 26, 2007 | 08:55 AM
kalister1's Avatar
kalister1
When my 93 SYS was flashing it was "LOSS OF SERIAL DATA" faults. Per the manual if this condition occurs after start up the engine will start again, if the condition does not clear out on it's own the injectors will not fire. IE: mine was intermittent so the car ran fine. After Trying to troubleshoot as best I could (FSM calls for J39700 and -10 adapter, -10 adapter is NOT available) I replaced my ECM with 1 from E-Bay and everything is OK now.
I do not remember my fault codes, But the Service ASR light lit along with flashing SYS and the A/C light flashed also.
Old Jun 26, 2007 | 12:41 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Funny you should say that about the ECM, I just replaced mine a couple of months ago.
Old Jun 26, 2007 | 02:06 PM
miris32's Avatar
miris32
I have had the same problem; it's intermittent. Clear all of your DTC's and monitor for a few days. I use the paper clip method to check for DTC's.
Since all of these codes were thrown together it is most likely a loose connection somewhere. Most of the circuits I have seen carry the hot wire right to the device, and close the ground in the circuit to minimize the risk of accidentally smoking a device or circuit via an inadvertant ground. You probably have a loose or corroded ground connector somewhere.
The FSM has a good ground distribution diagram, and I am planning to check the condition of each ground. Will let you know how I make out.
Old Jun 26, 2007 | 02:53 PM
sumorada's Avatar
sumorada
Default intermittent
i have 93 that also has intermittent problems,it will run great for 1-2 or 10 days then it starts coughing and backfires,sounds like it's only on 4 cylinders,system light plus security light flash and on the speed display it reads sys low,i had it looked at for the past 3 months by a couple different mechanics,they say that unless it happens while it's there they have no clue,can't get any codes etc. yesterday on my way to work it happened 100 feet from my mechanic so i went in he hooked it up while it was happening,he started checking the manifold air temp conn.said it was reading 32 degrees? called today said come get the care he has no clue what is wrong...i need help please! the computer was replaced 4 months ago along with alot of other crap,had the car for 5 years has 80,000 on it,drive it everyday until now it's been the perfect .help please i'm in fla. now used to live in pasadena area md.
Old Jun 27, 2007 | 11:51 AM
pcolt94's Avatar
pcolt94
I would almost point to the opti but you have to many other unrelated strange things happening. Its almost like the ECM & PCM are failing to operate normal due to a lack of full 12 volt input. The SYS low indicates low battery voltage for what ever reason and is read by the CCM. Almost sounds like there might be a bad connection somewhere causing all these strange things to happen. If this happens again, look at the volt meter in the dash to see what it says.
Might even monitor the 12 volts using a DVM from inside the car while you drive. Can pick up this point in lots of places but the cig lighter might be easy or aux wires under the center console. Also don’t forget about ground connections.
Just a thought and a starting place.
To CCM problems on a 93
